Old 03-08-2010, 09:36 AM   #1
JAB'70
Troubleshooting Assistance Please...
Alright, I took Ole B out for a cruise Saturday afternoon since it has been sitting for a while with all the rain and nasty weather the past month or so. The last time I drove it was in early January (I have been starting and running it every two weeks).
Like I said nice day took in on a spin, after about 4 or 5 miles while I was at a stop sign, as I pulled off I felt a good jolt then it just shut off on me (if it was a newbee I would think it was the timing belt). I got it over the side of the road, but could not find anything wrong. Full tank of gas, gas getting to the carb, good battery, crankshaft is turning, all indication is that it should start. The motor turns over (good strong revolutions) with good indications but it won't start. Seems like it's not getting any spark.
Putting it out for an analysis maybe someone has experienced the same thing.
JAB'70 is offline   Reply With Quote
Old 03-08-2010, 09:40 AM   #2
wHATANERD
wHATANERD's Avatar
Re: Troubleshooting Assistance Please...
Do you have an HEI, or Point type distributor? You might want to pull the distrubutor cap to see in the rotor is turning.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 03-08-2010, 09:42 AM   #3
Monte Carlo Man
It's time to take it to a garage buddy.
There is no way for anyone to diagnose your problems over the internet.
It wouldn't have hurt had to posted which engine, transmission, ignition system, wiring harness etc. was in the truck. Most anything can make a truck shut off and there is no timing belt in a small block Chevrolet - if that was what you have. There is no timing belt in a straight six 250 either.
Monte Carlo Man is offline   Reply With Quote
Old 03-08-2010, 10:20 AM   #4
blyguy
blyguy's Avatar
did u check your ignition source to your distributor? happened once to me where the wire came off the distributor, would crank like crazy but not fire.
blyguy is offline   Reply With Quote
Old 03-08-2010, 11:03 AM   #5
JAB'70
I understand there is not way for anyone to diagnose my problems over the internet. Just friendly conversation, exchanging ideals to see if I missed something (could be simple and I missed it) before I take it to my licensed mechanic. buddy.
Old 03-08-2010, 11:06 AM   #6
JAB'70
I have HEI.
I think it might be a the distributor.
Thanks for the replies.
Old 03-08-2010, 11:11 AM   #7
JAB'70
Smile Re: Troubleshooting Assistance Please...
Small block (only Chevys on this sight). I didn't say it was the timing belt. "If it was a newbie(later model vehicle with timing belts) the timing belt would have been my first guess."
Old 03-08-2010, 11:45 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
There are hundreds of problems solved on this forum and many others. What would you have him do run to a garage every time something simple goes wrong. I do agree that the more information a person gives the more it helps to troubleshoot a problem. I see it all the time mostly with new posters.
They fail to mention even what year their truck is or if it's a v-8 or six.
The op here has given enough information to get some ideas what the problem may be so he will get his problem fixed soon.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-08-2010, 12:11 PM   #9
jsbgump
Gone Fishing
jsbgump's Avatar
Check out the control module in the hei. Its a common problem
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 03-08-2010, 12:24 PM   #10
JAB'70
Sorry for not giving the full information, I typed without checking what was written.
1970 Chevrolet C-10, 350 V8, 4BBL, 5.7L. 65,000volt HEI distributor.
Did most of the work myself, so that's why I am a little stumped. I'm sure it's in the ball park of the distributor I was just trying to get opinions to help me along when I get under the hood. Thanks for all the positive ones.
Thanks MSGT you raised the flag at the right time.
Retired CWO3 Navy here.
Old 03-08-2010, 01:27 PM   #11
fleetimus
fleetimus's Avatar
Check your hot wire to the Hei. I went thru a similar scenario. Changed everything and it was the 12 volt wire to dizzie!! Bad connection at the fuse black!!
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 03-08-2010, 06:36 PM   #12
kacz81
kacz81's Avatar
i would agree would the control module i've had what sounds like same thing happen to me in my '85 c10 and in my buddy's 71 after going crazy checking everything but the control mod it was the control mod
kacz81 is offline   Reply With Quote
Old 03-08-2010, 06:59 PM   #13
matt67350
matt67350's Avatar
What are you running? V8, L6, or any other motor? You should check your timing and see if you have fire to the # 1 cylinder. That goes for any motor you have. Do you hear a knock when you try to crank the motor. Pull the valve cover and see if the valves are moving, also check for a bent pushrods.
For V8 pull the driverside valve cover. Good luck.
Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 03-08-2010, 07:01 PM   #14
cparman
sharp as a marble
Check to be sure that you do not have spark at the spark plug. If you do not have a spark tester, just use a screwdriver. Put the end of the screwdriver in the end of the spark plug wire and find a convenient place to ground the screwdriver. IF you have no spark, check to see if you have 12v+ at the wire where it connects to the dizzy. IF you have 12v+ at the dizzy the trouble is inside the dizzy.
cparman is offline   Reply With Quote
Old 03-08-2010, 07:10 PM   #15
Leviticus
Shake and Bake!
Leviticus's Avatar
This^^
And don't mind Monte Carlo Man, he has been acting like a little girl lately. We are all glad to help when we can, so ask away.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 03-08-2010, 08:57 PM   #16
JAB'70
Thanks for the suggestions. I will work my way through it.
Old 03-08-2010, 09:48 PM   #17
blyguy
blyguy's Avatar
let us know what it was, i am curious
1971 Chev C-10 SWB CST
2008 Chev 1500 Crew Cab LTZ
2010 VW EOS
2007 Harley Davidson Nighttrain
Old 03-09-2010, 01:00 AM   #18
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That's ok chief. I just disagreed and no offense meant to Monte either.
If you go to the top of this page there's a little box labeled user cp.
Click on that and it'll take you to a page called (your control panel) scroll down to the box labeled , edit signature, and click on that and it will let you make a signature with whatever you want in it. You can type in your info and you won't have to type it every time.
I got relatives in Charleston are you near there?
VetteVet
Old 03-09-2010, 10:28 AM   #19
JAB'70
Thanks for info, no pon intended with monte. Understand people's gestures. I live in Summerville about 25 miles NW off the I.
CWO3, USN, RET
When a man's ways please the Lord, He makes even his enemies to be at peace
with him.; A man's heart plans his way, But the Lord direct his steps." (Prov
16:7, 9 NKJV)
Never look down on anyone unless you are helping them up. SMS.
Old 03-15-2010, 08:42 AM   #20
JAB'70
It was the Ignition Control Module. Put a new in and I'm back on the road.
Thanks for all the help.
CWO3, USN, RET
16:7, 9 NKJV)
Old 03-15-2010, 08:59 AM   #21
cdowns
cdowns's Avatar
these motors dont have timing belts
Old 03-15-2010, 09:09 AM   #22
neba
would like to point out that the rotors on hei dist are known to burn through which will the cause the module to fail. if you turn rotor over and see a dark spot in center,its starting to arc through and should be replaced.
neba is offline   Reply With Quote
Old 03-15-2010, 09:17 AM   #23
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
also keep in mind that the Skip white NEW HEI is the same $$ as the module and it comes with the cap and rotor....so its really a saving to swap out the hole thing
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-15-2010, 09:44 AM   #24
neba
are you thinking a new dist is the same price as a module?
Old 03-15-2010, 10:07 AM   #25
Hottrucks
Hottrucks's Avatar
yea I priced a module for mine it was like $80..I could be wrong on what they cost..but the skip white HEI's are about $50 and thats complete including cap ,coil, new vacum advance, ..bla bla bal its NEW..pretty hard to beat that IMAO..
http://cgi.ebay.com/ebaymotors/SBC-C...%3D5%26ps%3D63
