Reverse lights
hey guys need some help, the transmission went in my uncles truck Im not real sure what year the truck is, because the guy built it as a plow truck. The steering column is 80's ish i guess because the wiper switch in on the column. Now the truck had a th350 in it, and we switched it out to a sm465 So as the title says how can i get reverse lights to work. Thanks for the help
Re: Reverse lights
you have a couple of things you could do. you could run a wire 12v + to the switch on the trans and run the other wire from the switch to the reverse lights.
another option is just to wire them up to a switch. in pa its legal to do that, but its just as easy to get them working the correct way |
