![]() Join Date: Jan 2001
Is this a good idea ?
I was replacing cab corners and rockers. Nothing that I can do can completely seal the rockers so at some point water is going to get in there and start to rust them. There is that urethane foam in an aerosol can . I use it to seal and insulate around windows in my house. You squirt it in and it expands to fill voids. Has anyone thought about filling the space behind the rockers and the cab supports with it ?
Bernie |
Resident Curmudgeon
![]() Join Date: Dec 1999
I believe that would do more harm than good by trapping moisture.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
We spray the inner parts with a thinned tar mixture to seal the seams and cover the surfaces. (Home made undercoat).
Jim |
![]() Join Date: Nov 2002
DO NOT use spray-in insulating foam.
You'll be sorry - if you do. It'll trap moisture and actually promote rusting. Personally, I like treat the bare metal with Metal Prep and then spray an undercoating in to seal it as best I can. That said, Eastwood offers some pretty good spray in coatings - some that would seem to be well suited for this purpose. Good Luck! Jeff ![]()
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
Insulated Foam !! (##?/>*!!)
Let me Find My pics of the problem from the previous owner. Probably kept him warm, but, created a giant sponge and no metal anymore. He INSULATED the cab supports, rockers (fully) and the cab corners, what a mess. I would not do that, unless, you plan on using it as a farm truck, but I think it might be harmful to the animals, SO I guess, it ain't worth Sh$$.. Just my .02$ (Bad Experience)
72 CHEVY FLEETSIDE 4X4 K10 (SOLD TO JAMIE72, BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!) Will Own one Again!!! 1967 CAMARO (PRO-TOURING PROJECT) Lawrenceburg, Indiana.. AOL IM: kbillcad |
Getting cabin fever?!?!?!
spray in foam sucks!!!!! there's no point in replacing all that metal, it'll rust out real quick. check the lower right hand corner of this pic. the foam was sprayed in from the inside.
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
TOTY 2006
A better option is to weld more sheetmetal in the bottom to close up the cab, and then put in a hole and a rubber plug (like what you see on most car floorboards. that way it is closed up (no more noise) and you still have the ability to open it up to air out.
its all about the +6 inches
You could coat the inside of the metal with POR 15.
Sooooo, I guess it's not a good idea. Thanks to all.
Bernie |
