Old 03-08-2010, 03:59 PM   #1
trevota
upgrade master.
I've looked without any luck.
Is there a "bolt on" master thats dual circuit? Im aware of brake line changes needed.
its for a 65 c20.
thanks
trevota is offline   Reply With Quote
Old 03-08-2010, 04:27 PM   #2
apachedaddy
apachedaddy's Avatar
Re: upgrade master.
Great write up and hope it helps you out...
http://67-72chevytrucks.com/vboard/s...d.php?t=332148
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 03-08-2010, 04:42 PM   #3
onequickchevy
onequickchevy's Avatar
Re: upgrade master.
I used a 76 manual disc brake master on mine. Had to shorten the rod a bit though. It bolted right on no problem.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 03-08-2010, 10:09 PM   #4
jason65
Registerd User
jason65's Avatar
Re: upgrade master.
I used cpp booster and master cylender and proportioning valve with C20 rear wheel cylenders and 84 C10 front disk. All on a C20.
jason65 is offline   Reply With Quote
Old 03-09-2010, 01:48 AM   #5
Captainfab
60-66 Nut
Re: upgrade master.
Are you looking for manual brakes or power brakes?
its for a 65 c20.
thanks
Old 03-09-2010, 12:09 PM   #6
trevota
Re: upgrade master.
manual brakes. All my brakes work good. I dont feel the need to swap to disc (c20=more work) and im fine with manual brakes. I dont drive the old girl much, and when i do, I like knowing that im driving a truck.
I just want the added piece of mind with a dual circuit master.
Old 03-09-2010, 12:15 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Re: upgrade master.
I used the 'Corvette' style ms/cyl for my truck. I am running disc, however. ChiefRocka has the correct ms/cyl in his thread, I believe.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-10-2010, 01:15 AM   #8
Captainfab
60-66 Nut
Re: upgrade master.
You could use a manual master cylinder from most any '67 to about '76 truck. However you will possibly need to modify the pushrod to fit the '65. The '67-'72's would probably be the closest match
