FAST LSx 102mm Intake
$840 shipped
FAST 146102 102mm LSXR INTAKE MANIFOLD for GM L92 / LS3 RECTANGULAR PORT FAST™ engineers teamed up with airflow specialists at RHS™ to develop a polymer intake manifold for rectangular port GM L92/LS3 engines. Testing on a stock LS3 engine with a Big Mouth 102mm Throttle Body™ produced gains of 14+ horsepower and 11+ ft/lbs of torque at the flywheel over the stock intake. The LSXR™ 102mm Intake Manifold features a three-piece modular design that allows easy disassembly and porting. Extensive testing led to a runner design that is longer and less restrictive and gives the user the ability to remove individual runners from the manifold for modification. Constructed from the same advanced polymer material as the LSX™ 92mm Intake Manifold, the LSXR™ offers a host of benefits over aluminum aftermarket intakes, including lighter weight, increased strength and improved heat dissipating characteristics. While the LSXR™ features a 102mm air inlet that is perfectly suited to the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock or aftermarket 90mm or 92mm throttle bodies. Other features include integrated nitrous bungs and perfect bolt-on fitment that allows the use of factory accessories without modification or clearance concerns.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 03-08-2010 at 05:10 PM. |
| Bookmarks |
