Post Whore
![]() Join Date: Feb 2000
Are there patch panels for these rust areas?
I know I can get a patch panel for the floor, but for the part of the floor that rises up to the dash, is there a replacement panel for that area or do I get to just get some sheetmetal and make it work?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Post Whore
And regarding the cowl area, it does not appear that the replacement patch panels that are available are going to be enough. Is it more sheetmetal work time?
Post Whore
View from the outside
Post Whore
Outside, side view
I havent heard of any time to break out the sheet metal. Had to do the same at the seam above the floor pan just used my vice like a sheetmetal brake. good luck looks like your gonna have alot of fun.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
![]() Join Date: May 2002
they do make sheetmetal replacement parts for that area. they are the kick panel patches. from LMC, they are 9 inches high from the floor to the top of the patch panel, and 11 inches from the pillar to the top of the angle. they also show to be $17.95 each, you choose the left or right side. hope this helps.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
