Cultural Infidel
![]() Join Date: Jan 2007
Where can I purchase a driven gear for a TH400? Also need the housing for a 41 tooth gear.
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold ![]() 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 ![]() ![]() It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
Re: speedo driven gear
Try just about any transmission repair shop. they typically stock that stuff
Active Member
![]() Join Date: Jul 2007
Or go to the dealer. Be sure and determine the color or number of gear teeth before going.
Here is a good reference but as the others said you should be able to get those locally without a problem.
http://www.transmissioncenter.net/sp...FQEziQod3SGNeQ |
Licensed to Thrill!
Slow Old Timer
![]() Join Date: Apr 2000
BowTieOverdrives.com too!
