Old 03-08-2010, 09:19 PM   #1
BOZO
Old School
BOZO's Avatar
V6 water pump on V8
I am installing a serpentine drive from a 1999 4.3 liter V6 on a
350 small block V8. Most everything seems to be pretty well
straight forward, including drilling & tapping the extra hole in
the passenger head. My question is, can I use the reverse
rotation water pump from the V6 or do I need to use something
different? If so what do I need?
The water pump will physically bolt up, but I am concerned
about the circulation. If somebody has been down this route
I would appreciate some feedback.
BOZO is offline   Reply With Quote
Old 03-08-2010, 09:49 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: V6 water pump on V8
It's the same part with the same part number for both V6 and V8 applications.
Old 03-08-2010, 10:37 PM   #3
silverstreak
I did a similar swap on a 70 Chevelle a few years ago and didn't have any problems from the reverse rotation. However, if you're running a mechanical fan, make sure you use the appropriate fan for the pump. Reverse rotation pumps require a fan with the blades angled opposite direction of a fan for a conventional pump, so it will still pull air through the radiator and not try to shove it into the radiator.
silverstreak is offline   Reply With Quote
Old 03-08-2010, 10:51 PM   #4
BOZO
Old School
BOZO's Avatar
Tx Firefighter,
THANKS
Old 03-08-2010, 10:57 PM   #5
Tx Firefighter
You bet buddy, I just went to O Reilly's website and cataloged a pump for a 4.3 V6 and a 5.7 V8 and they were the same part number.
Old 03-08-2010, 11:16 PM   #6
WHAMMYBAR66
WHAMMYBAR66's Avatar
Exclamation Re: V6 water pump on V8
DUDE ! I am doing the same swap !!
My problem is centered around the water pump too !! Mainly, the heater hoses.
The 4.3l pump I have has two metal heater hose ports and I don't know what I would do with them if I used it. Do you have any ideas on that ?
My current v-belt set up has one heater hose that goes to the intake and one to the water pump. I don't have a port on the passenger side of my radiator for a heater hose like some trucks so I need to get one hose back to the water pump.
I am trying to find a reverse flow water pump with only one heater hose port on the top center of the pump.. I have pics of one from another forum.. but can't find it so I can order it.
Post pics ASAP ! Any help appreciated !
Whammybar66
Hit me up with your thoughts in this ! Please !
WHAMMYBAR66 is offline   Reply With Quote
Old 03-09-2010, 01:26 AM   #7
wildwilly4x4
Go get a pump fpr a TBI rig, sound like yours is off a serpetine setup from the vortec gen 350s and 4.3s(96-99). The pumps from 88-94 or so should work just like your v-belt pump, they just spin backwards.
wildwilly4x4 is offline   Reply With Quote
