Old 03-09-2010, 03:40 AM   #1
Andrew68c10
Ball Joints
What tool would I use to remove and install lower ball joints?
68 C20
1968 Chevy C10 Longbed Fleetside
Andrew68c10 is offline   Reply With Quote
Old 03-09-2010, 06:55 AM   #2
wHATANERD
wHATANERD's Avatar
Re: Ball Joints
a shop press if the A-arm is removed from the truck.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 03-09-2010, 07:49 AM   #3
Jeffs70
Jeffs70's Avatar
Re: Ball Joints
I just installed mine a few days ago and to get the old ones out I just used a BFH and with a few hits on the stud it popped right out. you can rent a press for this from Autozone or Napa and some times other Part stores like Kragen. I used a large press I had in my shop and it didn't take much to pop the new ones in if you use axle bearing grease. you can make a sleeve that will not harm the area where the Zerk fitting screws in just at the edge of the Ball joint and it should pop in ok with a press or a nice clamp
Jeffs70 is offline   Reply With Quote
