Old 03-09-2010, 09:19 AM   #1
GreenAcres
"I tawt I taw a puddy tat!"
GreenAcres's Avatar
Question - 3/4 ton to 1/2 ton
Are six-lug and eight lug axles interchangable? What about the front?
Other "major" consideration to convert a '67 3/4 ton to 'XX 1/2 ton, 6-lug?
If there's been a thread in the past maybe someone knows the title, or can post a link?
Thanks,
John
'67 C/20 LWB CST 283/SM420 FleetWood - project "HELL!"
'68 GMC 1500 SWB Fleetside 250/TOT SOLD
'70 C/10 454/TH400 LWB SOLD
GreenAcres is offline   Reply With Quote
Old 03-09-2010, 09:38 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Question - 3/4 ton to 1/2 ton
The easiest way to do what you want is to find a 1/2 ton donor and swap the rearend and front cradle with suspension into your 3/4 ton frame.
If you get a '71 or '72 will have 5 lug wheels with disc brakes on the front.
There are other ways of doing it of course, but I have found this easiest.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-09-2010, 10:02 AM   #3
GreenAcres
GreenAcres's Avatar
Thanks Danny,
So other than the suspension, 1/2 and 3/4 ton frames are the same?
Old 03-09-2010, 10:12 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
The 3/4 ton and 1/2 ton frames are basically the same with a few differences.
The rear cab mounts on a 3/4 ton frame are lower to allow for a thicker rubber mount to allow for a smoother ride in the cab.
The 3/4 ton frame has extra bracing at the cross-member where the trailing arms mount and the trailing arms are stronger because the have extra plates on them.
I am sure some one will chime in with more informations.
Also the '67 frame does not have the dimple for the steering box.
Danny
