Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-09-2010, 11:21 AM   #1
iluvmy72
Got a Blazer....have some questions
OK...I just bought a Blazer last night. It's a 4 door 1993 with 4wd. The motor has been rebuilt with just 10 thousand miles on it. It drives but the trannny has issues with reverse and 1st gear. It wants to start with second gear. In driving it, I'd like to make just a few changes. Starting with the POS instrument panel. Has anyone here done the swap to the older one with the "round" indicators? And has anyone swapped out the front buckets seats for a bench? I want a bench seat......however I want a plush plush seat. What are the options? You'll have to forgive me guys.......I'm a full-size chevy dude with a history of burbs, tahoes, and the great 1972 chevy trucks!!!!! And is the motor I have a good one? It's is the L35. I believe these were batched delivery with fuel but cannot remember it has been so long. But thebn again I can't complain. I got the thing for 300 bucks.
iluvmy72 is offline   Reply With Quote
Old 03-09-2010, 02:00 PM   #2
Damien
Damien's Avatar
Re: Got a Blazer....have some questions
I think you have a 4l60e, Check the plug on the passenger side of the trans. If these a not connected tight you will have problems. Also check the module on the shifter shaft. Yes the CPI is batch fire.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-09-2010, 07:24 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
FYI low and reverse are on the same clutch pack in the tranny. I would test the fluid pressure before I tear into it.
not sure about the cluster issue.
I would think a bench from a like truck would work.
the 4.3 L35 is a Central Port Injection which means you have one injector with 6 spray nozles.
68C15 is offline   Reply With Quote
Old 04-23-2010, 11:19 PM   #4
iluvmy72
how do i test for fluid pressure? If it has no pressure, what do I check?
