Old 03-09-2010, 12:15 PM   #1
Jamokey
Lifting a Lowered Truck
The search engine isn't working for me. So I will ask the question.
I purchased a '67 SWB that was already lowered. Last year when i started driving it the front tires were rubbing on the inner fender wells, so I put smaller tires on the front to fix this. It has long headers on it that go under the front crossmember, now I find that the collector part of the headers when I drive over any dip in the road or speed bump rub the ground.(actually broke a bolt) There is about 2-3" of clearance as it sits. Is there any low dollar way to fix this.
I know I can change the exhaust but I would actually like to lift it a couple inches. Would different springs work?
The pic doesn't do it justice, it is lower than the picture looks. The bumper hits the ground when backing out of the driveway onto the road.
Jamokey is offline   Reply With Quote
Old 03-09-2010, 12:32 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Lifting a Lowered Truck
yes, you can put different springs to raise it back up. it probably has dropped spindles as well
so it probably has 2 1/2 dropped spindles and 3 inch drop springs..... as thats looks like a 5 /7 static drop to me. others will chime in
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-09-2010, 01:17 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Does it have lowering blocks between the rear trailing arms and the rear axle? What tire sizes are you running front/rear? Different springs will solve the problem in the front, we just have to figure out what's in there now. I do agree with my67chevytruck - that looks like at least a 5/7. If it has a lowering block in back you can take it out and use a taller spring in front. What is the measurement from the wheelwell to the ground on level pavement? They will help determine the amount of drop you have.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-09-2010, 01:17 PM   #4
mr48chev
mr48chev's Avatar
It looks just about the way My67Chevytruck described it. That is there are a combination of things done to get it that low.
First you need to figure out how it was lowered and then figure out how much you want to raise it back up and go from there.
I'd go with changing springs as that would be the least expensive and fairly simple to do. You might end up trying more than one set of springs to get it where you want (or need ) it to sit before you are done though.
Old 03-09-2010, 02:25 PM   #5
Jamokey
It has drop spindles on the front, however the rear has been converted to leaf springs, it looks like a stock bracket on the front part of the leaf but the rear is a homemade shackle. I can't remember the size of tires on the front( I think P205/55/17), but the rear are P235/75/17.
Also if I wanted to change the headers to some type of block huggers, which is the best way to go.
Old 03-09-2010, 03:13 PM   #6
sanford66
sanford66's Avatar
Nice truck! I like the way it sits, wish mine was that low! Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 03-09-2010, 04:13 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
Is the axle sitting on top of the leaf spring pack or below it? If you can find a stock leaf spring shackle that may give you an inch or two, depending on how for the 'homemade' shackle was meant to drop it.
Adam
Old 03-10-2010, 12:26 PM   #8
JWall
Frequent Flyer
JWall's Avatar
That is one good lookin' truck!
- Justin
1 Owner 1976 SWB
Old 03-10-2010, 01:21 PM   #9
Jamokey
Thanks guys. I think I may just change the exhaust to go over the crossmember that will probably fix the drag except for big ones. I do like the stance, and it will probably cost close to the same.
Old 03-10-2010, 01:48 PM   #10
coolbus4us
cuts corners
coolbus4us's Avatar
looks damn good to me.... fix the driveway before altering the stance of the truck
'68 Suburban named the "Cool Bus" by my kids
Follow the project here: http://67-72chevytrucks.com/vboard/s...d.php?t=331448
I love my Suburban.....a lot!
coolbus4us is offline   Reply With Quote
Old 03-10-2010, 03:57 PM   #11
Ackattack
Ackattack's Avatar
yeah you could put some shorty headers on it or stock manifolds. Really like the way it looks.
Ackattack is offline   Reply With Quote
