Old 03-09-2010, 12:53 PM   #1
primetime
primetime's Avatar
basic power disc swap?
how do i upgrade manual disc brakes to power disc brakes up front? do i simple remove the master cylinder and bolt up the new master cylinder w/vaccum booster? or is it a more complex swap?
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 03-10-2010, 10:27 AM   #2
primetime
primetime's Avatar
Re: basic power disc swap?
help please
Old 03-10-2010, 10:41 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Get you a booster and bracket set off the parts board or swap meet. Unbolt the master cylinder from the firewall and install the booster assembly. Hook the rod up to the pedal under the dash. Now bolt your master cylinder to the booster. Hook up the vacuum hose to the engine.
It's really that simple. You don't need to disconnect the brake lines or do any bleeding of the brakes. The existing brake lines will have plenty of play in them to reach just fine with the master cylinder bolted to the booster.
Old 03-10-2010, 11:20 AM   #4
primetime
primetime's Avatar
HEY THANKS MAN. i really appreciate the knowledge. it seemed like one of those things that might have hidden diffeculties that you don't catch until its too late.
Old 03-10-2010, 11:37 AM   #5
Tx Firefighter
Just beware that the booster requires two brackets to mount it to the firewall and a couple of pieces of linkage to connect the booster to the pedal.
You might send teeitup a private message. I have bought from him way too many times to remember. He parts out trucks and is my go-to guy for stuff like this to make sure every little trinket is included.
