Old 03-09-2010, 03:02 PM   #1
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
cheapest thermostat for electric fans?
looking for a cheap way to add electric fans. i have a nice size fan and shroud from a 03 lincoln towncar thats almost a perfect fit that i want to use. is there a cheap thermostt that i can buy to control it that is dependable? and how easy is it to hook up? i mean where does the temp sensor actually go? do i have to tee it off the block some way with my original one? cus that would look pretty tacky hangin from the side of the block
knightowl73 is offline   Reply With Quote
Old 03-09-2010, 03:41 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: cheapest thermostat for electric fans?
Installing the sensor in the passengerside heads it the best place. I use a Painless Wiring sensor. You can find part numbers at their website. You can order the parts at your local parts store, www.jegs.com, www.summitracing.com or www.jcwhitney.com.
I run a 205 on and a 190 off sensor.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-09-2010, 07:54 PM   #3
knightowl73
thank you, helps alot.
Old 03-09-2010, 08:44 PM   #4
spinem
haha, ford guys...
i use to use my eyes on the temp guage and a 20a switch hahah
spinem is offline   Reply With Quote
Old 03-09-2010, 09:16 PM   #5
knightowl73
yeah im not tryna have to do that at all. im watchn the temp guage too much now. i havent got the rockers adjusted right yet. been lazy, its only like a mile to my job thru backstreets so no biggie. but i think that is the reason it s running hot. some i believe are too tight. but i want the electric fan, cleans up my engne compartment alot. already ditched the inner fenders, made a battery tray, and re-ran some wiring too. thats why i was concerned about placement of the sensor and such. i want a clean look but still wth a/c.
Old 03-09-2010, 09:35 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have mine running on a ignition switched wire
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-09-2010, 09:46 PM   #7
USSkoval
Mine is running off of a cheap little controller that is also adjustable, and it works well. It was like 35 bucks, I have the part number written down somewhere.
USSkoval is offline   Reply With Quote
Old 03-09-2010, 11:37 PM   #8
knightowl73
really like the ones with the sender that screws into the head. im thinkin thats really all i need. i can use any 30a relay and make up the wiring myself. i think im at least that smart
Old 03-10-2010, 01:41 AM   #9
spinem
haha, ford guys...
2800CFM self contained thermostat, no wires, thermo control is on the side for easy adjustment.......and it still gets too hot... i will have to take this off this summer.... winter here is an average of 50F, summer, 90F+
Old 03-10-2010, 01:48 AM   #10
ocbaud
Garage Queen Material
i have a temp sensor in the pass. head that turns the fans on at 195.
also have a manual control so that I can turn them on whenever i want to. nice for piece of mind and at the track waiting in line
ocbaud is offline   Reply With Quote
