Old 03-09-2010, 03:17 PM   #1
Mccoleman830
Mccoleman830's Avatar
Vacuum pressure?
I have a 78' K15 with Gm performance engine # 10067353. What should the vacuum pressure reading be at 800 rpm idle? Currently it reads at 15". Is this correct or should it be higher? Any help? Thanks.
Mccoleman830 is offline   Reply With Quote
Old 03-09-2010, 03:37 PM   #2
MTCK
MTCK's Avatar
Re: Vacuum pressure?
I show about 18-19" with the same motor. You are in the ball park. If a cam was swapped that would change it. You might pick up a little bit by dialing in your idle mixture and ignition timing.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-09-2010, 03:42 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
That cam is really mild, I'd expect north of 20" Hg.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-09-2010, 05:23 PM   #4
Mccoleman830
As of this point no cam swap has happened. So far i just have a Edelbrock 1400 smog carburetor and and manifold. I thought it would be higher, more towards 18-20in. It runs fine. Just tuning the carb I've seen the pressure towards the lower end of the scale. I checked the manual, its stating it should be around 18-22in.
Old 03-09-2010, 06:01 PM   #5
64swb
64swb's Avatar
I have the same motor in my '78 K2500 and I've never been able to get anything more than 15'' of vacuum. It has about 20k on it now, and never been any different.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 03-11-2010, 05:22 PM   #6
Green Monster
Green Monster's Avatar
I was wondering the same thing. I just installed a vaccum gauge on my 72 Blazer with a 350 ci. and I'm also showing 15". It runs great.
Green Monster is offline   Reply With Quote
