03-09-2010, 08:48 PM | #1 |
HickTown
Open Headers Hurt???
I read somewhere that if you run your motor w/ open headers or no mufflers that the lack of backpressure can force to much cold air into the motor and somehow hurt the rings or something??? or hurt somepart of the engine causing a premature need to rebuild it?
Sooo.... would it hurt anything at all to hack the muffler off at the rear axle (where it currently sits) and run a strait pipe on my 250?? Thanks, Bryant
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
03-09-2010, 08:49 PM | #2 |
Between Trucks...
Re: Open Headers Hurt???
When I was planning a header swap I asked the same question. The general consensus was it's O.K. to run open headers.
Beat it to fit, Paint it to match... |
03-09-2010, 08:51 PM | #3 |
HickTown
you think it would hurt the engine at all??
03-09-2010, 08:56 PM | #4 |
Between Trucks...
Board members said it wouldn't hurt a thing.
03-09-2010, 09:15 PM | #5 |
I built it
imo i dont think it hurts anything. ive been runing glass packs (basicly straight pipes) for over a year and no problems. just run long enough pipes to get the exhaust away from the engine and you should be fine
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
03-09-2010, 09:19 PM | #6 |
TOTY 2006
yea, the thinking is that running just headers or just exhaust manifolds is that when you shut off engine, it is possible that cold air could travel up the exhaust and possibly warp the exhaust valves.
03-09-2010, 09:21 PM | #7 |
wont hurt a thing other than your ears....
03-09-2010, 09:31 PM | #8 |
I was so dam poor in high school that after I installed my headers [long tube] I had to drive it every day to school and then to work for eight months and only got warned once by the police and many other times by my neighbors.
03-09-2010, 09:51 PM | #9 |
its all about the +6 inches
it's total BS.
like the last few times this came up, I drove an 81 citation in highschool for 6 to 8 months with only an exhaust manifold through an ohio winter... no problems other than carbon monoxide intake and ringing ears. |
03-09-2010, 10:07 PM | #10 |
keeping your exaust gas tempetures down is a good thing for prolonging engine life with no back pressure you have nothing to hold the heat in whice is good in my opinion. but if you run extreme egts and the motor cools down to fast it can cause warp to the valves (not likely) most valves are made out of higher quality metal like titanium. my diesels go from 1300 to 300 in 5 seconds one thing i notice about gas engines is you will want your pipes to exit behind the cab and another thing is you do not get throttle responce with no back pressure we like to put something half way across the inside of the pipe and weld them in a few places still gives you the sound you want and the negitive pressure the engine needs to burn the air/fuel sitting in the intake
03-09-2010, 10:11 PM | #11 |
20' Daredevil (Ret)
*cough* WHAT?
03-09-2010, 10:30 PM | #12 |
GM ONLY BABY!!!
Drag racers run open headers all the time.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
03-09-2010, 10:46 PM | #13 | ||
"I ain't nobody, dork."
I have run open headers in drag cars for years... no problemo mang...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-10-2010, 12:10 AM | #14 |
Shake and Bake!
I put new headers on my 67 Camaro when I was 16, man I thought I was cool running them disconnected for a week or so
Warning though, it is LOUD, like other have said.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
03-10-2010, 12:41 AM | #15 |
Fighter aircraft in both world wars flew with stubby stacks often less than 6 inches. It's a myth that it is detrimental.
03-10-2010, 01:36 AM | #16 |
Big Red - Now its a SWB!
Open headers are fine, I ran mine a little while with just longtubes. I've heard that if you run an engine without headers/manifolds then you can warp valves.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
03-10-2010, 07:52 AM | #17 |
If it was the case of having it harm your motor and anything else then they wouldn't make Cutouts and People wouldn't install them..well I guess some would but It has never been proven to be a cause of ruining a motor or exhaust valves, Those parts said to be ruined by a burst of cool air is BS IMO. those parts are already way hot and no short burst of cool air is ever going to cool those parts down that fast to harm them, It would have to take many years for this to happen. The only reason this has ever been brought up as an excuse is to make everyone run Mufflers to quiet them down. All because of complaning people that have nothing better to worry about then their ears haha.
03-10-2010, 08:30 AM | #18 |
You`re not running open headers anyway.You`re running a straight pipe off the header(s),so it`s not the same issue even if there was one.You can grab the end of the pipe.Can`t grab the end of the header.Caveman say not same thing,UGH!
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-10-2010 at 08:30 AM. |
03-10-2010, 02:56 PM | #19 |
You can but I wouldn't recommend it!
03-10-2010, 05:20 PM | #20 |
Cool Truck
I have thought about running open headers on my 37 when I get it running after hearing my brothers 78 Caprice with open headers but I probably won't because it would be too loud. I will probably run 3 inch exhaust with electric cut outs and some flowmasters that dump in front of the rear tires.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
03-10-2010, 07:06 PM | #21 |
The only thing it will hurt, will be your pocket....when John law dont like it crazyL
http://community.webshots.com/user/hotrodhorn |
