Old 03-09-2010, 09:41 PM   #1
David67
David67's Avatar
Lowering
How low could I go before I would have to notch the frame?
David67 is offline   Reply With Quote
Old 03-09-2010, 09:45 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Lowering
I have had better than half a dozen of these trucks lowered 6 inches in the back without c notching any of them. I use ECE springs and do still haul with the truck so they don't get pampered. No issues with bottoming out.
Some guys will say 5 inches is the lowest without notching, but I can only offer my experience and ECE's recommendations.
Old 03-09-2010, 09:53 PM   #3
David67
David67's Avatar
Re: Lowering
Ok great. I was actually thinking about doing a 4/6 drop so this is awesome. Do you think I could lower it 6 inches with the stock springs?
Old 03-09-2010, 09:56 PM   #4
Tx Firefighter
Re: Lowering
You will have to change the springs to do a 6 inch drop.
Old 03-09-2010, 09:57 PM   #5
David67
David67's Avatar
Re: Lowering
ok thanks a lot!
Old 03-09-2010, 10:24 PM   #6
David67
David67's Avatar
Re: Lowering
Also one more thing, what did you do in combination with the springs or was it just the springs themselves?
Old 03-09-2010, 10:25 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Lowering
Kevin is right... 6" rear spring and you will be fine.
Lowered shocks and shock relocators to change the angle of the shock otherwise it will continue to bottom out.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-09-2010, 10:29 PM   #8
Tx Firefighter
Re: Lowering
And an adjustable track bar to recenter the rear end...
Old 03-09-2010, 10:29 PM   #9
David67
David67's Avatar
Re: Lowering
alright thanks
Old 03-09-2010, 10:36 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Lowering
Just contact ECE and they will set you up right.
-Nate
Old 03-10-2010, 12:06 AM   #11
lks dcvn
lks dcvn's Avatar
Re: Lowering
lks dcvn is offline   Reply With Quote
