tranny questions
Hi all, I have a 71 c/10 long bed. It had a 4 speed manual tranny(3 speed with granny gear) and I swaped it out for a th350. I believe the tranny is out of a late 70's early 80's truck. I know I needed a different drive shaft so I got one out of the junk yard, it had a different center bearing on it but i asumed i could get the right bearing for it. The truck I took the drive shaft from was also right around the same age (70-72) My problem is the shaft is way to long. To put the shaft where the center bearing needs to be the front of the shaft is all the way up to the tranny cross member. What gives do I need a drive shaft just for a 71? i figured they where the same from 67-72, Thanks
Grandpa in the rustmobile...
Re: tranny questions
id say motor/trans lwb swb make it all diff make sure its not longhorn either lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
hey thanks for the help
its all about the +6 inches
your shaft donor truck could have had a TH350, TH400, or even a powerglide.
Your TH350 in your truck may be a long shaft, when they all came with short shaft trans |
