Old 02-03-2003, 03:30 PM   #1
PHOENIX
Tall Valve Covers & EGR?
OK summit doesnt make those cast aluminum valve covers in the short style, then only have the tall style. I can get the Billet Specialties for $80 or these tall ones for $63. I think they are the same product, just marketed under different names for sales purposes. I think summit has t buy them in bulk from BS's to get the lower price, just my guess.
Anyway I know the tall covers will interfere with my EGR valve. Isnt there a spacer or something to move the EGR? Its probly not worth it, I should probly just spend the extra $20 and get the short type (BS). Either way I still want to know what can be done about tall covers and EGR valve problem.
One more thing. Could having tall covers hurt anything? I know that tall covers are for use with roller rockers, so they clear them. But if I used a tall cover with my stock setup, would that cause any problems, like oil flow or anything?
Thanks!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 02-03-2003, 06:25 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I've not seen a spacer for this. I don't think it can be done.
I know with my Billet Speciaities, I had to buy another stock GM spacer to move it up a little higher so it wouldn't hit. So now I have, a EGR gasket, spacer, gasket, spacer, gasket, and EGR. With this setup, I have about 3/16" between the EGR and valve cover.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-03-2003, 06:32 PM   #3
PHOENIX
My EGR pretty much rests on the valve covers now.
I have these on it now:
http://www.jegs.com/cgi-bin/ncommerc...00&prmenbr=361
Thanks Mike, that must be what I was thinking of.
I will most likely have to do the same.
Old 02-04-2003, 11:49 AM   #4
Marks 85
Color By Krylon
Marks 85's Avatar
Edelbrock makes an EGR relocator that you need to use w/ there carbs... Mabe that will work for you!!!
Marks 85 is offline   Reply With Quote
Old 02-04-2003, 01:17 PM   #5
PHOENIX
Will check into.
