Steering Column Shift Indicator Question
I found a non-tilt steering column off a 68 Sierra Grande at the wrecking yard. It was missing the pointer housing, shift indicator housing and lens. LMC lists the pointer housing for the column for that year but not the indicator housing and lens. It only list those for 1971-1972.. Can you use the 71-72 lens and housing? Thanks guys
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Steering Column Shift Indicator Question
I am in the same place as you, Mikey. I will wait a reply.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
