Old 03-10-2010, 03:16 AM   #1
roofingbloke
How much will i gain ?
Hi All. I have a static drop at the moment, but just like most of you guys i want to get the truck lower, However i have 4" between lower a arm and top spring mount, Question is, how much lower will an air bag get me when the bag is deflated,
I dont want to drive any lower than the ride height that i have at the moment but want the truck to sit lower when parked up.
Could someone post a picture of a deflated airbag and measure the distance for me.
roofingbloke is offline   Reply With Quote
Old 03-10-2010, 11:50 AM   #2
FnLow69
FnLow69's Avatar
Re: How much will i gain ?
after removing the bump stops i would say you would gain atleast 2" inches, possibly 3".
FnLow69 is offline   Reply With Quote
Old 03-10-2010, 12:08 PM   #3
roofingbloke
That sounds good, have you got any pictures, ?
Why is the top bag plate allways flat, could the upper side of the airbag be recessed into the upper support, or am i missing something.
Thanks.
Old 03-10-2010, 01:37 PM   #4
SCOTI
SCOTI's Avatar
Measure the distance between the C/L of the lower a-arm pivot point to the ground & figure that distance in your factors.
If the distance from that pivot point to the ground is greater that the distance between the bump-stop area (after removal of said bump-stop), the bump-stop dimension will tell you how much drop is to be gained. If the distance from the a-arm pivot point is less that the bump-stop area, the lower a-arm hitting the ground will be the limiting factor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-11-2010, 02:27 AM   #5
roofingbloke
Here is a picture from the air ride pages on this forum, but is this bag fully compressed cos if it is it dont look like i will gain anything,
Old 03-11-2010, 02:33 AM   #6
FnLow69
FnLow69's Avatar
doesnt look fully compressed at all, plus you wont need the lower cup that tall.
Old 03-11-2010, 02:44 AM   #7
roofingbloke
I agree, thats why i would like to see a picture like mine, off axle stands etc, I think you could loose about half the height of that lower bag cup/support.
Old 03-11-2010, 11:34 AM   #8
FnLow69
FnLow69's Avatar
ya sorry i cant help with the pictures, mines bagged but not on stock stuff.
