Old 03-10-2010, 10:46 AM   #1
Andrew68c10
Upper Control Arm Shaft
I just replaced my upper control arm shafts and tightened the caps and mounting bolts. One side moves freely and the other is really stiff to the point where it doesn't drop down under the weight of the spindle assembly. Is this a problem?
1968 Chevy C10 Longbed Fleetside
Andrew68c10 is offline   Reply With Quote
Old 03-10-2010, 04:02 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: Upper Control Arm Shaft
Have you greased them yet?
OhOneWS6 is offline   Reply With Quote
Old 03-10-2010, 04:22 PM   #3
Wrenchbender Ret
Is the shaft centered between the bushings? As long as it is centered & greased it will loosen up after a while.
Wrenchbender Ret is offline   Reply With Quote
