Old 03-10-2010, 11:21 AM   #1
67chevy2wd
67chevy2wd's Avatar
Mini spool or Locker?
I am looking to upgrade the open diff in my 71 GMC. I want to beable to drive this truck through anything but still beable to drive it on the roads, but I don't want to spend a bunch of money either. Is there anyone out there running a mini spool and driving their vehicle daily on the street? Or should I just save up and buy a locker? If I go with a locker what brand/style would you recommend?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-10-2010, 11:49 AM   #2
V30 mongo
Re: Mini spool or Locker?
Sounds to me like you need to go do some serious junk yard looking. A good find would be a 14 bolt from a 1 ton single wheel like a chevy military truck. They had 4.56's with the Eaton Gov-lock. There were lots of civy units too.
V30 mongo is offline   Reply With Quote
Old 03-10-2010, 01:29 PM   #3
67chevy2wd
67chevy2wd's Avatar
Is the gov lock similar to what is in my 2007 chevy duramax?
'71 GMC 3/4 ton 4x4
Old 03-10-2010, 08:17 PM   #4
LONGHAIR
You really don't want to run a spool on the street they are just a complete pain. They are purely racing stuff....
If you want max traction a Detriot Locker is the way to go, but they can be clunk on the street too. It's managable especially with an automatic, but you will know that it's back there.
Forget Gov-locks, they are NOT a locking device. It is simply a "variable pressure" clutch-type Posi-traction differential. The small ones are complete junk, the bigger 14 bolt units are stronger, but there are limits to them too.
There is no "cheap way" that will take any kind of abuse.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-11-2010, 07:04 AM   #5
Detroit Locker.Just drift your sharp turns and go light till straight when starting off making a turn.The CUCVs used lockers,not the Gov-Loc.The Gov-Loc in a 14-bolt is a good unit for what it`s designed for...on road use.They are a ball-ramp design and it takes wheel speed to engage.The trick is just enough to engage but not so hard you break something banging it in at higher wheel speed.This is no good to off road where you get up against stuff and need both wheels "now".I have one in my 3/4t Suburban with 35s.I like to do all I can in 2wd before relying on 4wd and it really helps.When in mud and it stops moving,I just spin the wheel at about 1500 rpm,then it bites and I get to churnin`my way out.It doesn`t disengage when you stop the wheel.You can rock it or whatever technique it takes.But,if you want both wheels full time so you can walk through it all,the locker is king.
Old 03-11-2010, 09:51 AM   #6
jake_t327
jake_t327's Avatar
I've got a mini spool in my '67 2wd, and it's terrible on the street. It chirps the tires when you go around corners and it's harder to steer and park. It's also hard on tires, so I'm going to take it out and put my spiders back in it I think, since i can't afford a locker, but I think there's some lockers out there that are quiet on the street and stuff, Powertrax makes one I think.
jake_t327 is offline   Reply With Quote
Old 03-11-2010, 10:24 AM   #7
low900rr
I would say no to a spool unless its srictly offroad truck or a truck your gonna race at the strip.
My builds
69 stepside.......2wd to 4wd
http://67-72chevytrucks.com/vboard/s...d.php?t=330675
and the new 66
http://67-72chevytrucks.com/vboard/s...d.php?t=302321
low900rr is offline   Reply With Quote
Old 03-12-2010, 09:26 AM   #8
duallyjams
duallyjams's Avatar
I have 4:10 and locker in a DD for the past 6yrs and have had no trouble and what is nice is the locker works in forward or reverse.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-13-2010, 10:28 AM   #9
eric67m
eric67m's Avatar
What about the Tru track (gear style) for the rear?
I have heard of people running detroit locker in the rear and a tru track in the front. Seems to be a popular combo.
But I am also budget limited (cheap)...... and looking for a less expensive way.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 03-13-2010, 04:19 PM   #10
LONGHAIR
I ran a Tru-Trac in a Dana 44 front years ago. It was great, but I have never even driven something with one in the rear.....clueless
But you aren't likely to save any money that way. Most any aftermarket differential is going to cost $450-$600
