Old 03-10-2010, 10:00 PM   #1
CHEMPOWR
CHEMPOWR's Avatar
Help with Collector bolts loosening
Can anyone recommend a solution for my situation. I am running a ball type collector system without a gasket. The bolts seem to loosen over time and develop leaks. I use lock washers and lock nuts which resist loosening because of the thread pattern. Does anyone know of anything else to use? High temp thread lock? The bolts are 2 inches long so I can't use the bolts with the self locking mechanism because they only come in 1 inch.
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs
1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI
2007 Chevy Corvette ZO6 427ci 505HP
CHEMPOWR is offline   Reply With Quote
Old 03-10-2010, 10:03 PM   #2
Paul M
Junior Member
Paul M's Avatar
Re: Help with Collector bolts loosening
had a similar issue with the 57 collectors. i went to the muffler shop and they just retightened and spot welded the nut to the bolt. never loosened again.
67-72 Truckless for the moment
Member# 1126
The one that got away http://customclassictrucks.com/featu...001/index.html
Paul M is offline   Reply With Quote
Old 03-10-2010, 10:05 PM   #3
CHEMPOWR
CHEMPOWR's Avatar
I could do that. Thanks for the suggestion. Be nice for something less permanent but will keep that in mind. Thanks
Old 03-10-2010, 10:07 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
use high temp forma gasket like a thread lock
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-10-2010, 10:22 PM   #5
crushermechanic
crushermechanic's Avatar
use 2 nuts jammed together. i had the same problem until i double nutted mine. no more leaks.
crushermechanic is offline   Reply With Quote
Old 03-11-2010, 08:32 AM   #6
CHEMPOWR
CHEMPOWR's Avatar
Thanks everyone. Now I have more than one way to skin a cat.
Old 03-11-2010, 11:26 AM   #7
junkman
longer bolts with springs in between the flange and bolts seem to work pretty good. I have had a couple sets of ball flanged header to exhaust connections and that has worked form me. Seems like a honda I had was like that from the factory, and kinda mimicked that setup. like this
http://www.summitracing.com/parts/WLK-35129/?rtype=10
junkman is offline   Reply With Quote
Old 03-11-2010, 01:55 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Have you tried using teflon tape on the bolt threads? I use it on my header flange bolts and I do not have any issues with the bolts coming loose.
Frank
piecesparts is offline   Reply With Quote
Old 03-11-2010, 05:53 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
High temp locknuts will take care of your issue. They are steel and do not have nylon insert like typical lock nuts. Instead they are crimped slightly when manufactured to make them self locking. Every jet engine out there uses them and they see very high temperatures and obviously don't loosen up in use.
Old 03-11-2010, 05:58 PM   #10
Shane
Shane's Avatar
NASA also uses the style nuts Tx Firefighter is talking about on things that are affected by temperature
Shane is offline   Reply With Quote
Old 03-11-2010, 06:16 PM   #11
Tx Firefighter
Hey, it's reliable enough for the space shuttle so....
Old 03-11-2010, 10:34 PM   #12
Billhilly
Billhilly's Avatar
I have used these on a few different jobs. Work great.
http://www.nordlock.com/default.asp?url=2.16.37
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 03-12-2010, 08:19 AM   #13
CHEMPOWR
CHEMPOWR's Avatar
Thanks everyone!
Old 03-12-2010, 10:38 AM   #14
junkyardjohn
junkyardjohn's Avatar
STAGE 8 LOCKING BOLTS. I'VE USED THEIR HEADER BOLTS & THEY ARE GREAT , & THEY SEEM TO MAKE EM FOR A BUNCH OF APPLICATIONS NOW. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-12-2010, 10:57 AM   #15
LONGHAIR
"All metal" lock nuts are known as "prevailing torque nuts". There are a few different types available.
One style looks very much like a nylon insert type. It has the ring around the top, but it is "crimped" to interfere with the threads. Tightening this nut "stretches" the crimp, holding it in place.
Another use a "crushing" of the nut into somewhat of a triangle. This puts more pressure on the threads too.
Others use various forms of "distorted" threads.
The stock rocker arm nuts are a good example of these. You just have to be aware that most of them will lose their holding ability with repeated removal-reinstallation.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-13-2010, 10:36 AM   #16
CHEMPOWR
CHEMPOWR's Avatar
Thanks everyone!
