03-10-2010, 10:56 PM | #1 |
Name that light socket?????
I stumbled on this light socked tucked behind my dash between the ashtray and the glovebox. Anyone got a clue to what it's supposed to be for? There was no bulb in the socket and when I tested it, the socket was HOT and unswitched. I needed a hot lead for the new radio so I use this one.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
03-10-2010, 10:59 PM | #2 |
Re: Name that light socket?????
appears to be a courtesy light. usually shines from under the dash on the floor area. it should be switched with the door pin which is negative.
http://www.gulftruckinc.com Last edited by thehitchmaster; 03-10-2010 at 11:00 PM. |
03-10-2010, 10:59 PM | #3 |
That is a courtesy light that mounts under the dash and comes on with the dome light. It works well to light up the floorboards.
CHEVY ONLY |
03-10-2010, 11:01 PM | #4 |
its a courtesy light, test it, close the door, and test it again. it mounts to the right of the ashtray. judging by the crimp connectors, it looks like a previous owner had some trouble with it, and tats probably why it isnt hooked up now
03-10-2010, 11:08 PM | #5 |
I thought it might be a courtesy light but the lead was hot even with the door closed. I'll have to trouble shoot it when I get the chance and maybe hook it back up. thanks guys.
03-10-2010, 11:10 PM | #6 |
it should be a switched ground. so it will have a constant 12v
http://www.gulftruckinc.com |
03-10-2010, 11:18 PM | #7 |
mut your ohm meter between ground and the - terminal in the socket, should be less than an ohm, then close the door, should be open
03-11-2010, 04:22 AM | #8 |
Right turn Clyde
Turn your headlight stalk ccw and it will also illuminate that lamp.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
03-11-2010, 11:46 AM | #9 |
That is what I was thinking also. It is the light for under the dash that goes with the dome light when the door is open. In my truck if I turn my headlight switch ccw the light under the dash is the only one that comes on.
03-11-2010, 02:18 PM | #10 |
That's the way mine works too on my '73.
