Old 03-10-2010, 11:23 PM   #1
amcgeh01
amcgeh01's Avatar
Any 5.3 Conversions out there w/4x4...?
If so, I have a question regarding the usage of the original transmission support mount which also cradled the NP208 case.....? I am getting close to installation and was wondering if anyone has done this already and what you used to cradle both the new 4L60/65e and the t-case... If I can still use the original then great - no money wasted... If you found you could not use it, then please list what or how you resolved it.. Thanks in advance..
- A.J.
In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks..
amcgeh01 is offline   Reply With Quote
Old 03-14-2010, 12:25 AM   #2
amcgeh01
amcgeh01's Avatar
Re: Any 5.3 Conversions out there w/4x4...?
** Bump **.. Still looking for some input on this one...
Old 03-14-2010, 02:45 AM   #3
72truckman
72truckman's Avatar
Could just build a simple square steel crossmember...
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 03-14-2010, 09:07 AM   #4
Thealien
Thealien's Avatar
Nevermind I relooked at your build thread. NV4500 so no trans issues. Do you just have engine mounts and no crossmember?
72truckman, Can I see your engine mounting/crossmember? Are you running a lift? Any driveshaft/transmission pan interferance issues?
I am in the middle of an NP205/4L60 5.3 swap on a stock height Jimmy. I believe I have the differential/crossmember interferance taken care of. I need to test fit then powdercoat the crossmember and then tackle modifying the tranny pan. Interested in how you handled your installation.
Old 03-14-2010, 01:53 PM   #5
72truckman
72truckman's Avatar
From the factory, all of the new Gen. III and IV blocks ares structural and used as a crossmember. I just made simple frame mount perches with polyurethane insulators.
Work in Progress
Old 03-16-2010, 10:34 AM   #6
wheatlysk5
ON my 4l60e i used the original crossmember and built it up with some sq tubing and then used the factory 4l60e rubber mount.
wheatlysk5 is offline   Reply With Quote
Old 03-24-2010, 07:36 PM   #7
amcgeh01
amcgeh01's Avatar
HI Wheatly,
Did you happen by chance to take some pics of your design so I can look at it to see if that's what I need..? Thanks..
