Old 03-11-2010, 12:37 AM   #1
60apache
60apache's Avatar
rear axle question
would the 1972 rear axle with coil springs be a bolt in on a 1960? is it 5 lug?
60apache is offline   Reply With Quote
Old 03-11-2010, 01:03 AM   #2
Captainfab
60-66 Nut
Re: rear axle question
Yes it is 5 lug......I replied to your other post asking the same question.
Old 03-11-2010, 09:29 AM   #3
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Actually, Captainfab, this makes 3 times. Lots of questions about rear ends on the forum lately, giving you many chances to "reiterate" certain facts.
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-11-2010, 01:07 PM   #4
60apache
60apache's Avatar
Thank you captainfab. I did go back and read the other post great info. so in your opinion what should I do? redrill my rear end thats in the truck, use this 80 rear end that I have, or get the 72?
Old 03-12-2010, 02:36 AM   #5
Captainfab
60-66 Nut
Well I would say it depends on which one has the gear ratio you need and what it will cost to make the necessary changes. Changing your original rear end to 5 lug will require machine work. The '72 will require some cutting and welding. The '81 you got with the frame will require some cutting and welding also, but it will have the bigger brakes. Is the '81 rear end a 12 bolt or a 10 bolt? Do you know anyone that can help you with either the machining or the cutting and welding? Or are you capable yourself? Keep in mind that the welding needs to be done by a competent weldor since this requires good welds on a critical component.
Old 03-12-2010, 02:02 PM   #6
60apache
60apache's Avatar
its a 10 bolt I have access to machine shops and fabrication shops. so I could do any of the 3 options
Old 03-18-2010, 06:06 PM   #7
60apache
60apache's Avatar
bump for captainfab. I am putting the front end in today. also ordered my wheels today. so I am down to deciding between the stock rear end or the 80 model I have sitting here. Which do you think would be a better choice?
Old 03-19-2010, 01:41 AM   #8
Captainfab
60-66 Nut
I would go with the '80 model rear end. It has the bigger brakes and is already 5 lug. The only unknown at this point is the gear ratios of the two rear ends. The '80 rear end is probably going to be higher geared. What bolt pattern of wheels did you order? 5x5 or 5x4.75?
