Old 03-11-2010, 01:36 AM   #1
25872burb
R&R rear air ac unit for burb
My rear ac unit is out of the burb (bought it that way). The motor still works. Is it only the motor under the cover or is there something else that I am missing. The motor has two wires on it (power and ground) but there are (4) wires running to where the motor mounts? Seems relatively simple to put back together, Am I right? Any help would be great. Thanks
Les
25872burb is offline   Reply With Quote
Old 03-21-2010, 07:49 PM   #2
AzDon
AzDon's Avatar
Re: R&R rear air ac unit for burb
To be an A/C unit, it would need to be an evaporator ( looks like an aluminum trans cooler) with an expansion valve and two hoses running to it, and a shrouded fan blowing thru it. If you have two A/C units, each of the hoses will tee into their respective hoses in the front system.
AzDon is offline   Reply With Quote
Old 03-21-2010, 11:41 PM   #3
25872burb
Thank you for the response. I actually got a little smarter over the last week, and realized the evaporator is at the back of the blower motor, in other words its all one unit, which I didn't realize. Thanks again, your input was helpful.
