Old 03-11-2010, 10:11 AM   #1
steelhorse
steelhorse's Avatar
CPP rear springs
I remember a while back people were saying the cpp rear springs were too soft and were bottoming out.Do they still have this problem?I am about to order the lowering kit for my truck and only want to do this once.I am plaining on going with 2.5 drop spindles,1 inch front springs and either 4 or 5 inch rear springs.I dont want to c notch my frame,will I be ok a with 5 inch drop in the rear?
steelhorse is offline   Reply With Quote
Old 03-11-2010, 10:19 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: CPP rear springs
Might want to get the adjustable track bar and shock relocators....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-11-2010, 11:22 AM   #3
Fitz
If you drop the rear that far the track bar will bind and you will have a bear of a time with shocks. There are several places where you can get an adjustable track bar, track bar relocator and shock mount relocation kit that will allow your rear suspension to work correctly with the shorter springs. CPP has the right pieces as does Early Classic Enterprises.
Fitz is offline   Reply With Quote
Old 03-11-2010, 11:30 AM   #4
steelhorse
steelhorse's Avatar
I was planning on getting the shock relocator and adj. track bar.I was just wondering about the spring quality/stiffness.I want to make sure I dont bottom out over bumps.
Old 03-11-2010, 03:36 PM   #5
ShredSled
ShredSled's Avatar
I'm in the same boat. But I'm also looking at doing their bolt-in c-notch.
But I see they have the springs in regular drop version, but also drop HD... I was assuming those would be too rough though, since I'd rarely be hauling a load and never towing with this truck...
ShredSled is offline   Reply With Quote
Old 03-11-2010, 05:42 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I have run quite a few sets of Early Classic 6 inch springs on my different trucks over the years. They are sufficiently stiff to still haul. I hauled Honda Goldwings in the bed of my 72 stepside several times with no undue bottoming out. They did bottom occasionally with the bike in the bed, but not enough to be annoying or justify c-notching the truck. Unloaded, no bottoming issues at all.
I can't speak of CPP springs with any first hand experience.
Old 03-11-2010, 10:17 PM   #7
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
just get the heavy duty 4" springs they sell and some 1" drop blocks...
Beatcoaster is offline   Reply With Quote
Old 03-12-2010, 12:55 AM   #8
Dynomutt
Dynomutt's Avatar
I bought the 4" drop standard duty CPP springs and they are WAY too soft in my opinion. I just replaced them with the 4" drop heavy duty CPP springs and I am MUCH happier with these.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 03-12-2010, 01:01 AM   #9
Dynomutt
Dynomutt's Avatar
Here are a couple of pics to give you a little visual difference in the springs.
MARQ
Build Thread
Old 03-12-2010, 01:10 AM   #10
ShredSled
ShredSled's Avatar
hmmm....
Just curious, did you put them on a long bed, or short bed? Gas tank relocated to the back frame?
And how did you decide they were too soft? I know this can be kind of a personal opinion, but did you have excessive bottoming or something?
get it!
Old 03-12-2010, 04:17 AM   #11
Dynomutt
Dynomutt's Avatar
Long bed and the tank was not relocated yet.
You're right, this is very much a personal preference thing that's why I said they were too soft in my opinion.
I weight just shy of 180 and I could stand in the back of my truck and the rear end was on the bump stops, and yes that is with the proper shocks, etc. When I would hit a bump at about 30, the rear would hit the bump stops. I'm just not a fan of that soft of a spring.
MARQ
Build Thread
Old 03-12-2010, 06:30 AM   #12
Jeffs70
Jeffs70's Avatar
Those top springs look just like Jeep Wrangler Rear Coils to me.
also this gave me some great info as I am about to do this with my truck in the rear. as I just did a full frame swap from leafs to coils.
Jeffs70 is offline   Reply With Quote
Old 03-12-2010, 09:51 AM   #13
steelhorse
steelhorse's Avatar
Thanks,I didnt know they offered Heavy duty springs.
Old 03-12-2010, 11:35 AM   #14
Beatcoaster
69 Fleetside
only in 2" and 4" drops though...so if you want lower you need to add some blocks
Old 03-12-2010, 01:09 PM   #15
BluTrukker
BOHICA
BluTrukker's Avatar
How low can you go before you need a new track bar and relocate the shocks?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 03-12-2010, 02:08 PM   #16
Beatcoaster
69 Fleetside
I'm going with the 4" HD's and hoping I don't have to do either, but we shall see...
Old 03-12-2010, 03:13 PM   #17
Bruce88
Bruce88's Avatar
My 72 short bed is currently tore down for rebuild, but when it was together and a 4 inch drop springs in the rear suspension I took some measurements of shock and suspension travel. I just posted a shock relocation picture I generated that you might want to take a look at to help determine how much you would like to drop your aft suspension (post # 257) http://67-72chevytrucks.com/vboard/s...318544&page=11
From my understanding I have soft springs and plan on using air shocks to compensate for carrying loads. From my calculations any drop more than 4 inch springs will almost be sitting on the rubber frame stops. And the use of drop blocks to get additional drop you might have to be concerned with scraping the shock relocater with a flat tire. So with any thing more than 4 inch drop other considerations will need to be considered.
I haven’t taken any measurement to see if there’s any interference with the bed floor or any other components but you might be able to gain an additional ½ inch suspension travel by taking a ½ inch off the frame rubber stop (just a thought).
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 03-12-2010, 04:12 PM   #18
ShredSled
ShredSled's Avatar
ah gotcha! Just trying to see how close my opinion might align with others on here, you know.
The long bed might have just a bit to do with it, but still, bottoming out on the bump stops when you're simply standing in the bed, hmmm... that's not good.
I still don't know which route I'm gonna go, but I do want more drop than 4" and don't want to lower the trailing arms too much with too much block, but this would also be going into a step-side bed so the load would be lighter and less leverage.
get it!
