02-03-2003, 07:00 PM | #1 |
did the th400 metric trannies have a lockup verter
i need to know whether or not all the th400 metris=c trannies have a lockup converter or not and how to tell if they do or dont.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-03-2003, 07:35 PM | #2 |
Fabricate till you "puke"
I dont know of any 400 turbos with lock up converter. some of the 350 turbos did have a lock up (350C)....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-03-2003, 07:42 PM | #3 |
ok i was asking because i know a lot of the metric 350's had a lockup verter and a friend was asking about a 400 hes going to use in his chevy.thank u
02-04-2003, 12:23 AM | #4 |
its all about the +6 inches
Never heard of a metric 350 or 400....the 200 was refered to as a metric though.
If it actually has a desicnation od C after the name, then it is in fack a lock up tranny... But I'm with crazy Al on this...never heard of a lock up 400. lock up isn't all ppl make it out to be. 200 RPM drop is not much. Just enough to hear and to take away the torque. |
02-04-2003, 01:09 AM | #5 |
i dont too much care for the lockup myself but the pan says metric on it and the tranny is from an 82 i believe i was just asking for a buddy
02-04-2003, 01:50 AM | #6 |
metric or not
I'm with the others, I've never heard of a metric 350 or 400, if it says metric on the pan then it's probably a 200 or a 2004R. Myself i don't mind the lockup, course I have mine fixed so I can shut it off if I want and then for road driving kick it back on, cause when a lockup up convertor is unlocked they generate imense heat and fast. i suppose all you Chevy guys will hate me when you find out that as my name says 86K10 is powered by a 7.5L
Oldsmobile. Hey at least it's GM. And it was just an experiment I've always wanted to try. It worked out quite well, now that it has been changed from 3:08 to 4:10 gears and a 69 C20 rear axle with detroit locker, it's a regular powerhouse and still only runs 2200 RPM at 75MPH. |
02-04-2003, 09:39 AM | #7 |
I am running a 700r4 without the lockup in my 68. I am not sure of the rear end gears but it works great.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
02-04-2003, 10:13 AM | #8 |
I just looked at several transmission sites on the internet. They all list T-350s w/ lockup and without lockups, but none mention lockup at all for the 400s. Judging from that, my bet would be that there are not any T-400 lockup transmissions.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
02-05-2003, 12:22 AM | #9 |
Ive often wondered if a switch-pitch pump/front support could be modified to work a lock-up convertor.
02-06-2003, 12:25 AM | #10 |
If memory serves, you need a special verter to run switch pitch.
