Old 03-11-2010, 09:07 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Body Swap question (60-66 cab & bed on 77' 2wd Blazer frame)
Greetings from the 73-87 Square Body side..............
Although I am a square body man, I always had a special affenity for those 60-66 trucks. Have any of you guys swapped a 60-66 cab & bed onto a 73-87 frame? The reason I ask is that I have a 77' 2wd Blazer I picked up 4 months back for $ 200 (no motor or trans). The kicker is that it came sans title. I am having one hell of a time getting any info from the State of Maryland as to the last titled owner. I might end up pulling everything off of it I can use and junking the body. I now I am dealing with a 106" frame. Is it possible to do?
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 03-11-2010, 09:36 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Body Swap question (60-66 cab & bed on 77' 2wd Blazer frame)
check out the k5 66 build in the projects and builds section!
Old 03-11-2010, 11:47 PM   #3
halfcockedcustoms
halfcockedcustoms's Avatar
a blazer frame is shorter than a shortbed,,,so if it did work it would look goofy,,,my .02
halfcockedcustoms is offline   Reply With Quote
Old 03-12-2010, 01:39 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
60-66 wheelbase is 115'' I believe.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-12-2010, 02:05 AM   #5
Captainfab
60-66 Nut
I have mounted a '62 SWB body onto a '74 SWB frame. I would not recommend it in a 2wd application as the side profile on the '73-'87 frames are a bit different than the '63-'72 frames. To mount the older bodies on the '73+ frames you will need to it one of 2 ways. 1) build new body mount brackets on the frame which translates to about a 3" body lift whick looks about like a stock K10. 2) channel the body down over the frame. Mainly the box and the rear of the cab.
I would stay with a '63-'66 frame and just transfer all the running gear from the '77 Blazer. If you don't have a frame, you can also use a '67-'72 frame with minor modifications.
Old 03-12-2010, 07:44 AM   #6
ECU PIRATE
ECU PIRATE's Avatar
Thanks guys. You have been very helpful. I guess I will scrap that idea on look for a roller to satisfy my hunger in the near future
The Fleet........
Old 03-12-2010, 08:57 AM   #7
jason65
Registerd User
jason65's Avatar
Do you have any pics of that?
jason65 is offline   Reply With Quote
Old 03-13-2010, 02:03 AM   #8
Captainfab
60-66 Nut
I don't currently have anything that shows much. I need to get a hold of the guy that owns the truck now and see if I can get some pics. I've been meaning to do that since this question seems to come up a lot.
