Old 03-11-2010, 11:14 PM   #1
scottsdaleowner75
Which 4 inch lift?
I recently got my hands on a 1986 Scottsdale shortbed and i want to lift it a bit to fit 33's without any rubbing. My question is who makes the best lift that requires the minimum amount of other modifications? What i mean is will i automatically have to lower the transfer case? Or get new brake lines? Or a new pitman arm? Or lengthen the driveshafts? I am not opposed to putting it together right i just rather get a kit that is straight forward and doesnt require a bunch of other mods.(if that is even possible) I wont do any severe off roading but i am looking for the smoothest ride i can get. It doesnt need to be bulletproof off road racing setup just something i can take on the weekends and hit the firetrails with. Any help would be greatly appreciated. Thanks and really enjoy the forums!
scottsdaleowner75 is offline   Reply With Quote
Old 03-12-2010, 08:26 AM   #2
LONGHAIR
Re: Which 4 inch lift?
A 4 inch kit really doesn't require much in the way of other modifications. The brakelines will need to be re-located, but they don't need to be disconnected to do it, so no bleeding. 99% of the time there is no need to do anything with the driveshafts, no transfer case mods either.
I would however get the raised steering arm. It just makes everything better on the street and off-road. It takes the angle/bind off ot the drag-link and makes for much better steering.
As far as brand names, I have always liked Rancho, but there are others. Tuff Country, Rough Country, SkyJacker, TrailMaster, etc are all good.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-12-2010, 08:47 AM   #3
msgross
msgross's Avatar
as stated the amount of modification will be based on how high you go... some kits are more complete and offer those extra items, but you could easily build your own kit as well...
Lifting a solid axle truck is pretty straight forward though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-12-2010, 06:40 PM   #4
scottsdaleowner75
Ok so the more i research this the more i see kits with rear blocks or add a leaf or whole spring pack. I used the search function and came up with the tuff country's ez-ride being the softest ride. What kind of ride would i get with hydro shocks instead of nitro shocks?
Old 03-12-2010, 06:49 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I had 4" Superlift springs front and rear with the Skyjacker Nitro shocks in a 1979 GMC 3/4 ton. Worked great! I had 35" BFG M/T's on it too... I had to do a little front fender trimming, but nothing major.
Remember to get the correct steering arm for your truck. If not you'll have all kinds of probs with steering geometry.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-12-2010, 08:15 PM   #6
scottsdaleowner75
I was looking here http://www.ntwonline.com/73-87_1_2T_..._KITS_C824.cfm
specifically at these two kits
http://www.ntwonline.com/73-87_GM_1_...P12762C824.cfm
http://www.ntwonline.com/73-87_GM_1_..._P8379C824.cfm
It looks like both come with the steering arm, and all four shocks. Whats the difference between the two? Is Suspension Special NTW's house brand? Would these kits be all i need to get that little extra lift i am looking for to run 33's or 35's?
Old 03-13-2010, 12:17 AM   #7
GASoline71
GASoline71's Avatar
That is who I got my lift kit from... I had to buy the steering arm seperate though. Then again I lifted my truck 20 years ago...
Gary
Old 03-13-2010, 12:23 AM   #8
scottsdaleowner75
I wonder which of the two kits i linked to has a more comfortable ride?
Old 03-14-2010, 07:35 AM   #9
wildwilly4x4
for just running 33's I'd just trim the fenders a lil bit...it should barely even be noticable how much you would have to trim. I have never driven a chevy with a lift that drives worth a crap, compared to stock. And thats with all of the correct steering whatzits and all. My blazer now has a 4" lift and 35" TSLs, and it drives somewhat better with x-over steering from ORD, but it really needs a panhard bar to feel "right"...just my 2 cents.
wildwilly4x4 is offline   Reply With Quote
Old 03-14-2010, 01:37 PM   #10
scottsdaleowner75
Mostly i want to level it a bit. It has 32x12.5x15's in there now but it has a slight rake in the front. I measured and it is about 1.5 inch difference in the front. If not a full four inch lift then what would you suggest?
Old 03-14-2010, 11:36 PM   #11
RaysK20
Your front springs and bushings are probably already sacked out in the front from age. I used 2 1/2 tuff countrys on my old short bed and it picked it up over 3 inch. I used a add a leaf in the rear but a block should give a smoother ride. The ride was better both on and off road. I used RS 5000 shocks from rancho. No steering mods were needed and the stock drive lines still fit.
RaysK20 is offline   Reply With Quote
Old 03-14-2010, 11:41 PM   #12
blazin
i have skyjacker 6 inch springs in the front of my blazer with bds springs in the rear. both are great springs... bds are alot cheaper and they make a great product.
blazin is offline   Reply With Quote
Old 03-15-2010, 01:31 AM   #13
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
the ride quality or COMFORT level depends on the spring rating and shocks...there's a write up around here on spring rating and how to determine what type of spring rating you'll want. it's on my laptop...unfortunately, i'm not on my laptop or i'd look it up
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 03-15-2010, 07:48 AM   #14
wildwilly4x4
Offroad Design offers a "zero" rate lift that would be perfect for leveling it out, and NOT changing the ride characteristics. It basically looks like a lift block for the front..( BIG NO NO!), but it works like an add-a-leaf...as in it bolts in with a new leaf spring bolt. I'm not sure on the sizes they offer, but 1" is what comes to mind.
Old 03-16-2010, 10:22 AM   #15
scottsdaleowner75
i checked out the ORD add a leaf/block and i may go that route. although through alot of online research and questions i have seen the 4" lift running 35" tires without any issues. so i could just do that as well. i would prefer larger tires so i will be ordering the rough country kit tonight.
Old 03-18-2010, 12:41 PM   #16
starter02
I also wanted the 4" lift kit from Rough Country, so I order it last friday the 12th. And found out it is on Backorder until mid April. So good luck getting one of the 4" kits from them unless you want to wait that long. My problem is I already started tearing my truck apart when I thought it would be delivery this weekend...
starter02 is offline   Reply With Quote
Old 03-18-2010, 05:05 PM   #17
scottsdaleowner75
i found it through other retailers so if their site is updated then i should be OK. But thanks for the heads up. I probably wont order until i get the engine back to factory configuration with all the smog crap on it. Which will be about a month.
Old 03-18-2010, 07:08 PM   #18
Oilbrnr
Oilbrnr's Avatar
I really like the Tuff Country's I put in my Blazer. I did a shackle flip in the rear with 2" TCs and 4" in front with the zero rate. Bought everything from ORD, and they were great to work with. Used their greasable bushings too.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 03-18-2010, 07:35 PM   #19
Mr-Jack
Mr-Jack's Avatar
Hey Don,
How much did those TC 2" lift springs actually lift the rear of your truck with that flip? i'm thinkin about doing the same thing and wanted to know. just trying to figure out if the TC 2" lift springs are centered or not Do you know by chance
Old 03-18-2010, 08:16 PM   #20
Oilbrnr
Oilbrnr's Avatar
Mr-Jack, I'd say that the two combined came to around 5-5.5" of lift. Originally, I tried to save some $$$ by re-using the original rear springs. Six months later I noticed that both had broken leafs. With the new 2" TCs I needed the 1" zero rate up front to level things out.
FWIW I also replaced the brake lines, dropped the rear parking brake brackets, extended the front driveline, CV and driveline extension in the rear and put a raised steering arm on. Still needs x-over.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-18-2010, 08:51 PM   #21
Mr-Jack
Mr-Jack's Avatar
interesting...so you think with the flip and 3" springs the rear would get around 6-7" of lift in the rear?
Old 03-19-2010, 01:43 AM   #22
Oilbrnr
Oilbrnr's Avatar
Yup.
Realize that flips have their pros and cons. As does larger arched leafs.
Depends on how you are going to drive the truck.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-19-2010, 02:11 AM   #23
Mr-Jack
Mr-Jack's Avatar
what are the cons of a flip? you referring to axle-wrap? i'll be driving mostly on the street, but will see the offroad as well lightly for the most part, but i want it capable of rugged terrain when needed. this will be a nice truck after i'm done, but i want it to be a capable truck as well. not just something that looks good sitting on the pavement
Old 03-19-2010, 01:01 PM   #24
Oilbrnr
Oilbrnr's Avatar
Pinion angle changes, in my case enough that I had to put a CV on the rear driveline. More work to install than just springs, on a K5 you'll need to drop the tank. They also change the handling characteristics while cornering.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-19-2010, 05:41 PM   #25
Mr-Jack
Mr-Jack's Avatar
Not trying to be a smartass, but lifted trucks were never really built to handle well when cornering.
I am not concerned with the drivelines cause i'm replacing them anyways. I plan on pointing the pinion straight at the output shaft of the transfer case and welding new spring perches on anyways, so i'm not concerned about any of that. i'm more concerned about keeping it level. front and rear
