Old 02-03-2003, 08:00 PM   #1
67cst
i love summertime
67cst's Avatar
does size really matter???
im going to be gettign an air cleaner pretty quick for the 327, does the diameter matter? i was thinking about getting a little one for now, does it suck less or starve the engine of air? any facts would be great, btw this is a pretty stock 327 engine...
thanks dudes
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-03-2003, 08:13 PM   #2
Blue68
Blue68's Avatar
Go here:
http://www.knfilters.com/facts.htm#SELECT
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 02-03-2003, 08:17 PM   #3
67cst
i love summertime
67cst's Avatar
it appears so...hmmm now the next question..do they make like an 8-10" diameter filter? i dont like those 14" beasts too much, they seem to bulky for a small block...maybe you guys could post pics of yours to give me an idea ...
thanks, Derek
Old 02-03-2003, 08:40 PM   #4
crazy longhorn
Fabricate till you "puke"
I have a 14x4 K&N on the longhorn.....probably a little overkill, but with no inner fenders there is a lot more dust. I cant post from webshots, but there are some pics with a 14x3 k&N (last yrs filter)...... http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-03-2003, 09:27 PM   #5
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Here is my 350 w/ 14x4 K&N....
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 02-03-2003, 09:45 PM   #6
Stano
Stano's Avatar
Heres my 14 incher. 14x3 I think. I have the tall valve covers so that may make it look a little different too.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 02-03-2003, 09:46 PM   #7
Reumster
L.E.D. Freak
Reumster's Avatar
I run a 14X5 K&N on mine. Maybe over kill, but not if you don't clean it very often! LOL But I think that more important than size would be cold air intake set-up. The worst thing you can do is pull in hot air from your engine bay.
www.ramairbox.com
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 02-03-2003, 09:52 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
Big is cool!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-04-2003, 12:12 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think the little dinkey ones look funny, and a 14 inch that is only 1 or 2 inhes tall looks way funny.
But that's just me though. Here's mine. This is the engine I'm running now, but in the old Longhorn.
Old 02-04-2003, 12:26 PM   #10
Lippyp
English Chevy Owner
Lippyp's Avatar
Here's my dinky little K&N, does the job much better than the crappy triangular edelbrock foam thing that was on there before. Had to stick with a small one because of clearance issues with coil etc, besides I got it cheap at a show!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 02-04-2003, 08:43 PM   #11
67cst
i love summertime
67cst's Avatar
lippyp- you raised another question, im runngin points and of course there is a coil there, will this limit the diameter i can go?
Old 02-05-2003, 06:05 AM   #12
Lippyp
English Chevy Owner
Lippyp's Avatar
The easiest way to gauge your maximum filter size would be to hold a piece of string on the centre of your carb and swing it around, shortening it until it clears everything, then measure and double it to get the maximum diameter allowing a little clearance for engine movement .
My V8 is in the I6 position so clearance is a little tighter than if it was in the normal V8 position. I guess I could have moved the coil and fitted a larger filter, but as I said I got the top and bottom plates cheap from a K&N stand at a show.
Phil
'67 C10 long fleet.
Old 02-05-2003, 03:00 PM   #13
69sixpackbee
Heres mine on the 402..
Guess what it originally came on?
And yes it does fit the standard q'jet carb.
69sixpackbee is offline   Reply With Quote
Old 02-06-2003, 12:19 AM   #14
Longhorn Man
Personally, I'd swap over to HEI...best bang for the buck you could ever do.
And if you don't do that, at least relocate the coil so you can get a full size filter.
Old 02-06-2003, 07:01 AM   #15
Lippyp
English Chevy Owner
Lippyp's Avatar
My K&N is 9" diameter btw and is supposed to be good for up to 250hp according to K&N's rep. My engine is pretty much stock apart from a Mallory twin point distributor and the Carter AFB as far as I know. (I am two owners down the line since it was built)
Phil
'67 C10 long fleet.
