Old 03-12-2010, 02:36 AM   #1
Ackattack
Ackattack's Avatar
Needed: Brake lever pin
Does any have or know where to get a brake lever pin. The pin I'm refering to goes on the back of the master cylinder. The lever has 3 holes in it, the bottom hole bolts to the bracket itself and pivots off of that. The middle hole goes to the brake pedal through the fire wall and the top one goes to the back of the brake booster.
I need the pin/spring clip that goes to the middle hole. I lost mine somewhere along the way of doing my restoration. Right now there is a bolt on there with a lock nut, however the bolt is too short that I can't get the locknut to "engage" the locking feature. There isn't enough room for a longer bolt. I haven't found any where that sells them.
So if someone has one around or knows where to get one let me know.
Ackattack is offline   Reply With Quote
Old 03-12-2010, 02:29 PM   #2
Ackattack
Ackattack's Avatar
Re: Needed: Brake lever pin
Buhler, Buhler???
Old 03-12-2010, 02:32 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
Check with Livrat, ClassicHeartbeat, or Pickmup-they might be able to hook you up.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-12-2010, 07:03 PM   #4
mbgmike
There is really nothing special about it. Any pin the right size will work. Go to a good hardware store
mbgmike is offline   Reply With Quote
Old 03-12-2010, 07:12 PM   #5
cdowns
cdowns's Avatar
b4 going measure thge inside diameter of the hole and the length needed so you can get one that fits
