Old 03-12-2010, 09:55 AM   #1
steelhorse
steelhorse's Avatar
Sway bar
Does anyone know if the sway bar from a 73-87 c10 will fit on a 71 c10?I have one I can get free brackets and all.
steelhorse is offline   Reply With Quote
Old 03-12-2010, 10:47 AM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Re: Sway bar
Oh yeah, they are the same. I pulled mine from a junked mid 70s C30, bought new bushings, sprayed it, then got better handling.
You will need to remove 2 rivets on the front crossmember for the mounting brackets.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 03-12-2010, 11:21 AM   #3
steelhorse
steelhorse's Avatar
Re: Sway bar
Thanks!That should save some coin for something else.
Old 03-12-2010, 11:13 PM   #4
capev86
Re: Sway bar
find a 1-1/4" sway bar from a 73-87 3/4 ton camper special or 1 ton. the biggest bar on our trucks and the next generation was only 1-1/8." if you are gonna go to the trouble, get the best bang for the buck.
capev86 is offline   Reply With Quote
