Old 03-12-2010, 05:40 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
ccp tubular motor mount perches
Does anyone know if the ccp sbc tubular perches will work with a bbc? or is there another reputable company that has good quality products that I should use? Im just not sure how I feel about the factory bbc stands and really dont wanna pay 250 for a set + motor mounts...
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 03-12-2010, 06:05 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: ccp tubular motor mount perches
I have a set of those exact ones, the gray powder coated ones, couldnt use them cuz I wanted to set the engine back to the rear mount, I used POL perches, still use the pin type motor mount. I am not sure if a pin type motor mount will work on a BB. If you interested in these, PM me, will make you a good deal.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-17-2010, 08:16 PM   #3
Wildstreak
Wildstreak's Avatar
so these would work with the front holes on the engine crossmember? how tight is the fit between the firewall and dizzy using the rear holes?
57 chevy 4x4
68 burb 2wd:
