Old 03-12-2010, 08:59 PM   #1
Low84
Low84's Avatar
Exhaust manifold bolts (need size)
We'll since I'm out on a week long break, I decided to finish off the truck's engine once and for all. I need to hook the stock exhaust manifold back into the engine. However, I don't have the old bolts and I'm having trouble finding new ones. I went to O'reilys and they first tried to sell me the head bolt kit, then the exhaust flange stud kit. But isn't the flange kit well....the one that connects to the pipe? I need the bolts that go to the engine heads. I had set a goal to have it up and running by tonight.
If anyone knows the correct size, name, or even a part number for the exhaust manifold-to-heads bolts. I would greatly appreciate it.
Oh, and i know the A/C compressor bracket hooks up to one of the bolts on the exhaust manifold....does this one have to be longer?
It's an 84 350 by the way.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 03-12-2010, 09:44 PM   #2
Low84
Low84's Avatar
Re: Exhaust manifold bolts (need size)
3/8" x 2 1/4" L
sound about right?
Old 03-12-2010, 09:45 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Tractor Supply sells grade 8 bolts for 4 bucks a pound. Just take your manifold in and get 3/8 bolts the right length. You need 1/2 inch of bolt thread sticking out past the manifold for good thread engagement into your heads.
Old 03-12-2010, 11:46 PM   #4
Low84
Low84's Avatar
Thanks a lot! Yeah I tried a spare screw and it went 3/4" in to the heads. So I factored in the 1 1/2" and it came up to a 2 1/4" total length. I'm thinking it might be a better idea to get 2" bolts so it can pull tighter though.
But O'reily's has them for $1.15 a bolt!! thats near $17 on bolts, I'm trying tractor supply tomorrow.
Old 03-13-2010, 11:21 PM   #5
Low84
Low84's Avatar
Well, no surprise here....but I ran into some problems.
Did I install the a/c compressor wrong? The long bracket that goes on the block has a provision which I'm sure is supposed to fit into the hole in the A/C bracket....but it's an inch or so off.
Old 03-25-2010, 12:00 AM   #6
Low84
Low84's Avatar
anybody?
Old 04-01-2010, 07:36 PM   #7
Low84
Low84's Avatar
Well big thanks to Slonaker for providing me with much needed pics of how to assemble this thing. I'm that much closer to finishing the engine.
Picture me rollin! Haha, I'm having dreams of driving the truck already.
Old 04-01-2010, 07:38 PM   #8
Low84
Low84's Avatar
Anyway, I would appreciate it if anybody had close up pictures of how and where the three wires that attach to the carburetor linkage go.
I also seem to be in need of replacing one of those wires that extends down to the transmission. What's it called?
Old 04-01-2010, 10:30 PM   #9
Low84
Low84's Avatar
Nevermind, I figured it out. I still need to know the name of the cable that extends down to the transmission. Is that the "kickdown" cable?
