Old 03-13-2010, 02:31 AM   #1
rev616
sbc swap question
this may be a dumb question.my 61 has a 235 and a 3 on the tree.what will need to be done to put a small block in with that trans??
rev616 is offline   Reply With Quote
Old 03-13-2010, 02:51 AM   #2
Captainfab
60-66 Nut
Re: sbc swap question
You will need to change the bellhousing to one from a V8 or an I6. Your truck being a '61 has a hydraulic clutch. Finding a V8 bellhousing that will accept the clutch slave cylinder will not be easy ('60-'62 only). However you can use one designed for a mechanical clutch. '63-'67 has the small center hole ( 4 5/8"), and '68-'72 has the larger hole (5 1/8"). You will just need to either buy a hydraulic conversion or fabricate one yourself. Novak adapters sells the conversion kit. If you cannot find a bellhousing locally let me know.
http://www.novak-adapt.com/catalog/kit_hcr3.htm
Old 03-13-2010, 04:39 PM   #3
62gmc910
62gmc910's Avatar
If you can't find a hyd clutch bell , scarce as hens teeth, but your hyd clutch slave is in good shape you can modify it to fit the left hand opening quite easily , the clutch fork from your 235 bell will work "my" modification works with the stock cylinder
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
