Old 03-13-2010, 03:36 AM   #1
skoffice
skoffice's Avatar
Cab Bushings
Anyone know if the bushings for 67-72 trucks will work on my 64? I have a set of energy bushings brand new in the box from my old 67 and was hoping they would fit. I know they're different part numbers, but how different could they possibly be? Just the regular old 1/2 ton 2wd. Thanks
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 03-13-2010, 05:11 PM   #2
ConnDemned
Re: Cab Bushings
I don't know, I have been looking for some and cab mounts for the later years are cheaper... Anyone know if they would work?
ConnDemned is offline   Reply With Quote
Old 03-13-2010, 05:35 PM   #3
mbgmike
Re: Cab Bushings
The only differance I know is that the holes in the frame mounts are smaller on the 60-66 they are just under 1.1/4 the later years like 1.1/2" you would have to enlarge the hole to get the bushing to sit correct in the hole, The rubber donuts are the same height. Think you will have to change two bolts cause i think the 60-66 are shorter a little bit.
mbgmike is offline   Reply With Quote
Old 03-13-2010, 06:58 PM   #4
skoffice
skoffice's Avatar
Re: Cab Bushings
Thats not even a big deal at all. Great! Now that you mention it, the holes do seem a little smaller..
