Do the factory Rams Horn manifolds come in different sizes? How well do they flow? I've seen them called "Rams horn Headers", but they all look about the same. My engine is a little warmer than stock, so I don't need super hi flow headers. Actually, I'm beginning to think the lack of back pressure in my system (shorty headers into 2 1/2 inch tube and mini turbo muffs) is causing the hesitation I have.
Reason I ask is I can get a pair for next to nothing, and as another board member said, it does away with the constant gasket failure on a header setup. Cnut |
Re: Rams horn manifold question
Rams horn exhaust manifolds come in 2" and 2 1/2" sizes. They probably will not flow as well as your headers.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#3 | |
The Older Generation
LockDoc
I thought the Vette ram horn and truck ram horn were different. The Vette ones are the better flowing ones. The truck ones with the kink at the bottom are the more restrictive ones. Not sure how the truck ones that are not kinked compare to the Vette ones.
Thanks for the info. I'm going to measure them before I buy them. I think they're the 2" though, and wouldn't do what I want. Thanks again, Cnut
#6 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Sure wish I still owned those cars... ![]()
not cheap but speedway motors sells TruRam manifolds for chevys and y block f**ds
The Corvette type Ramhorns w/ 2 1/2 in. outlets are reproduced now & are not expensive.
![]() Join Date: Nov 2003
If anyone is interested.
Speedway Motors sells a 2- 1/2" Corvette Style exhaust manifold for $59.95 each. These were patterned off of the early 60's 327 Corvette If someone knows of a better price maybe they will post up here? Ron
1972 C30 Cheyenne Super 1971 C10 (Parts truck) |
