Still plays with trucks
I need a set of 3/4-ton lower A-arms for my C2500 disc brake swap but there are no C20 or C30 trucks in the wrecking yard around here at the moment.
There are a few G30 vans that share the lower ball joint with the C20 & C30 but the interchange book says the A-arms are different. Anybody know what is different about the van lower A-arms that make the interchange book say they won't work on a truck? If there were any 2-wd trucks in the wrecking yard I would tear some off a van and see if they fit the truck but there are none to be found at the moment. Any help would be greatly appreciated.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
At the body shop.
Re: lower A-arm interchange
I believe the van stuff uses a rubber bushings. Where the 3/4 ton trucks use a threaded steel insert bushing
" That didnt make it any newer " " Dont antique the equipment " |
#3 | |
I will take a trip to the yard today and see if they have anything new that isn't on the web site yet. Maybe I will get lucky and find the C20 parts I know will work. If they have a C10 I will see how the van part looks / fits on it.
