T5 Mustang Trans in C-10?????
First, I know I used a bad word here and I am sorry. Please forgive me.
Now to the meat of the question. We have been on the hunt for a T5 trans from a Camaro to put into our truck. However, the search has been less than fruitful. (Already know that we will change the tail housing for the S-10 model to get the shifter in the right place.) Basically the people who have them want more than we are willing to pay. There also seems to be a lot of the F*** brand versions of the trans for a more reasonable cost. I now that the input-output shafts are different, but think this is still do-able. Has anyone ever tried this? Thanks, MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
Out of the carpool lane.
Re: T5 Mustang Trans in C-10?????
I think it would work just fine as long as you made an adaptor plate to fit between the trans and the bellhousing. Perhaps you could come up with some other way to mount it properly with some creativity. That's the only obstacle you'll have to overcome.
Oh, btw V8 Camaro trans around here are going for about $350 which seems kinda spendy to me. I've stumbled upon a few at around $150-200 but that's a rarity.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 03-13-2010 at 01:41 PM. |
You can get a conversion bell housing, but those can be as much as or more than the trans. Keisler sells a reproduction bell housing that may work, but you'd have to call them to be sure. One thing about an SBC is that you can adapt just about any common trans to fit behind it with a conversion bell.
Quicktime and Lakewood both make bellhousings to do what you are looking to do. |
look for chevy astro van with 4.3 5-speed it uses the ford bolt pattern on the trans and of course the chevy pattern on the motor side of bell housing. kind of rare but cheap if you can find. I got trans and bell housing for 100 dollars at local pull your own parts.
The T-5's a scrawny little thing for a heavy old truck, even the T5 World Class.
Be sure to at least replace the T5's front bearing & your pilot bushing/bearing before installing.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Ditto, If it was me, i would be looking for a NV3500. I know of a couple of those here in a local Junkyard I know of. I've had the T5's behind mildly built 350, You have to be really careful with them. Thats my .O2 cents worth
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
While I don't have any first hand experience, I've done a crap load of research on different trans for our trucks and the general concensus is the T5 is not a strong enough tranny for these trucks.
Cool Truck
I have had a T5 out of an 83 Camaro in my truck since February 09 and it seems pretty good. I had to get it rebuilt in Decemeber because two teeth broke on the counter gear or something, but there may have been some damage done to it before I got it because it was used in a race car.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
Big Red - Now its a SWB!
I wanted a t-5 but then when searching I found out that if your engine is putting out 300 pounds of torque or more then the t-5 won't last long. I'm now looking for a t-56 but those are pretty spendy ($1000-1500 for the whole setup).
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
the best thing to do is put your feelers out for a c20 ROCKCrusher, Mucie 4 sp, youll have all the bases covered with one of those, got one in mine and it Rocks
![]() Join Date: May 2008
I tore up 3 T-5 trannys behind my 327 375 horse before I went with a Tremec TKO 600. Sure they cost $2200 bucks but I have a lifetime warranty on labor. It would be ashame if you go thru all that work to convert a F*** tranny and later blow it up. How valuable is your time? My Tremec rocks and you get the overdrive!
Mine is chopped, has a clutch, and a big block. |
#12 | ||
2.20-1 first gear with a 1-1 high gear is just not enough spread. Those things were designed for muscle cars with low gears....high winding small blocks for road racing or "short bursts" like drag racing.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
