Six in a row makes it go...
![]() Join Date: Mar 2009
One-piece driveshaft in a long-bed?
My '66 long bed came from the factory with a 327 and TH400 (which were long gone by the time I got the truck).
![]() I installed a Richmond 5-speed, which is somewhat longer. I had the forward drive shaft shortened, but i sometimes wonder if it would have been better to make-up a one-piece shaft. Is this doable??
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Re: One-piece driveshaft in a long-bed?
Yes. I recently did a 3-speed Turbo HydraMatic conversion from a granny 4-speed. It had a two piece with a carrier bearing and I converted it to a single-piece and eliminated the carrier bearing. Due to the extra length, going from a two-piece to a 1-piece driveshaft, the diameter was larger on the new single-piece shaft. Out the door, it was $160.00, including tax, built, balanced, painted and new "U" joints. In my opinion, well worth the investment and improvement.
#3 | |
GMCMG 1964 GMC 1/2 ton LWB project - 1982 GMC 6.2 diesel engine/suspension donor - 1966 Chevy 3/4 ton frame/doors/fenders donor - tons of parts - cause you can't build a truck without 4 of everything! 2001 3/4HD Duramax Diesel extended cab lwb4x4 1984 Chevy C30 6.2 diesel lift truck (project) 1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!) glascock.m@hotmail.com |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I'm just not understanding everyone wanting to go to a one piece drive shaft on a long bed. Is it because you guys have the light duty driveshafts. IMO the heavier two piece driveshafts that I am used to seeing are much stronger than a one piece driveshaft that long.
#5 | |
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce Last edited by Shaky; 03-14-2010 at 07:06 AM. |
60-66 Nut
I've not had any problems in the past with a shorter forward driveshaft. But like I said, 90% of my experience has been with the heavier drive shafts (about 3" OD) with the bigger carrier bearing, not the puny driveshafts (about 2" OD) that had the carrier bearing hanging from the top
Thanks. Yes, I have the light duty version. If I locate a heavy-duty one, it should bolt-in (except for the shortening) right?
Registerd User
When I put the 700R4 in the driveshaft place said my front shaft was getting to short. I had it shortend going from the 4speed to the th350. They said it would cause vibrations if I shortend it any more. So, 700 with a one peice drive shaft. Still got my original driveshafts just in case.
#9 | |
1962 C-10
Yeah, Jason's is a longbed. I worked on a '63 longbed years back. The carrier bearing went bad. I chose to have a one piece made. Back then it was about $100 bucks. Worked out great. It was a th350, long tail shaft, I believe.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Just here to tinker
![]() Join Date: Jun 2008
My '60 longbed has a one piece drive shaft from the fatory. Did they start putting in two-pieces when they changed frames in '63?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
I don't remember. You have rear leaf springs in yours Cort?
Nevermind, I just saw the trailer hitch picture and noticed the rear coils. Last edited by justcuz; 03-24-2010 at 05:16 PM. |
