Old 03-13-2010, 02:59 PM   #1
69grygost
turn signal ???
Got a 69 and the signals are jacked up, the left side just comes on dont flash, when i put the right on both signals and the tag light flashes, and with the hazards on they all flash like they are supposed to. A friend of mine told me that changin the signal switch would probably fix it but just got that done today and no change, oh and btw sometimes they work right any thoughts??? thanks
69grygost is offline   Reply With Quote
Old 03-13-2010, 04:30 PM   #2
rusty baker
'70 C-10 Primer
rusty baker's Avatar
Re: turn signal ???
Sounds like a bad ground.
rusty baker is offline   Reply With Quote
Old 03-13-2010, 06:28 PM   #3
NVJason
NVJason's Avatar
Re: turn signal ???
I agree... you have a bad ground in the turn signal circuit. Check both front and rear.
NVJason is offline   Reply With Quote
Old 03-13-2010, 06:56 PM   #4
big mike71
big mike71's Avatar
Re: turn signal ???
Did you change the flasher.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 03-13-2010, 07:26 PM   #5
69grygost
Re: turn signal ???
ok thanks, no i havent changed the flasher
Old 03-13-2010, 07:35 PM   #6
rusty baker
'70 C-10 Primer
Re: turn signal ???
I think it is a ground because I had the exact same thing with mine. Also, I don't think a bad flasher would affect the license plate light.
Old 03-13-2010, 07:52 PM   #7
69grygost
Re: turn signal ???
okay by chance would you know where that is
Old 03-13-2010, 07:57 PM   #8
rusty baker
'70 C-10 Primer
Re: turn signal ???
You have to make sure that all the sockets are clean and grounded to the body. If just one isn't, the lights don't work right.
Old 03-13-2010, 08:31 PM   #9
69grygost
Re: turn signal ???
o ok thanks
Old 03-13-2010, 09:03 PM   #10
NVJason
NVJason's Avatar
Re: turn signal ???
I wouldn't suspect the flasher, it uses the same one for both sides so it is working properly if it flashes at all. Most likely you have a bad ground and the power is flowing through the bulb but not to ground. Since the bulbs are dual filament and both filaments are grounded together the power is feeding back through the park lamp filament and circuit to another ground.
