03-13-2010, 08:17 PM | #1 |
Beer Drink'n Knuckle Dragger
Question bout my options
I'm planning on lifting my 67 lwb 4x4 gmc when i get home and i'm looking for a kit, so here's what i'm thinking about.
I want an all spring lift and i'm looking for 6" to clear 35's I want it done tastefully and don't want to have to go back and re-do it. I don't mind adding in differant hangers or shackles, just don't want to go blocks at all. I would prefer a bolt on kit so it will b quicker, but I can manage some welding too. I just want to get it in the air and on the road asap. I've been looking around, and it is hard to find a 6" lift for GMC 4x4's in 67. Does anyone know what other years/make lift kits are compatible with what i have? I have 10 bolts on my 1/2 ton. I don't want to spend an arm and a leg, but will be adding new shocks and probably upgrade the steering at the same time. Also...(and this may sound like a dumb question) the lug patterns are 6 on 5.5's right? I mean that is all i've known for chevy 6 lug axles, but i could be wrong. Just want to make sure. For Rims i'm thinking about a 16x8 or 15x8 inch rim (any specific backspacing i should be after? Sorry for all the questions, just want to have all the parts sitting in my garage for when i get home so i can get to work. (i'm deployed and will have all this sent to my house). Thanks in advance fellas, Jack
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
03-13-2010, 09:09 PM | #2 |
Re: Question bout my options
I don`t think you`ll find bolt-on springs for pre-69.Short of custom springs or having a shop arch you some,you`ll want to get hangers from the`69-ups.I guess you could bolt the later narrower springs on with using spacers.
Yeas,6 0n 5.5 and about 4" backspacing is good. Good luck!Sounds like a plan!
03-13-2010, 09:13 PM | #3 |
what are so differant from 67 to 69 pickups with the springs?
what are the lengths for the stock springs on 67 and 69. Are the 67's wider? i wish i saw someone that has done this already so i could take a look at what all they did.
03-13-2010, 09:17 PM | #4 |
would this work?
http://www.superlift.com/Catalog.asp?P=K408&V=35 6" superlift and i would get the rear springs also found this...can i swap in 52" springs in the front and go this route? http://diy4x.com/cart/index.php?rout...product_id=122 or this flip? http://diy4x.com/cart/index.php?rout...product_id=112
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 03-13-2010 at 09:38 PM. |
03-13-2010, 09:42 PM | #5 |
found these ORD for the rear...but i would hate to use the stock springs and add 2"s with shackles anyone know of a spring i could use to get a couple extra inches with a better arch or a hyprid spring pack i could build?
http://www.offroaddesign.com/catalog/shacklekit.htm
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 03-13-2010 at 09:43 PM. Reason: meant to edit previous post |
03-13-2010, 10:35 PM | #6 |
Strongman Garage
The 67-68 springs are wider if I remember right, I went with a kit from www.diy4x.com to run 52" springs from the back of a 73-87 supposed to give 4-5" of lift and a diy4x shackle flip for the rear which gives 4" of lift I went with a 1" lift block and a bit longer shackles as well to offset the weight of the burb.
You can also get custom made springs, I forget the name of the company that I looked into before I went a different route but I think it was 150 or 200 bucks for every inch of lift? The rear springs are slso wider and a different length in the rear of 67-68 4x4s Here is my build thread with aforementioned parts. Its a little more involved than replacing springs but not to bad. http://www.67-72chevytrucks.com/vboa...d.php?t=312252
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
03-13-2010, 11:09 PM | #7 |
so let me get this straight...cause i can't see the pics at work cause the content filter blocks them (i'll look in about 6 hours when i get off tho)
In the front of your rig you used the diy4x b52 hanger, 52" springs and shackles In the rear you used the diy4x flip 1" block and longer shackles? You were trying to accomplish 4" all the way around for a heavier vehicle right? So i could essentially get longer shackles in the front and rear to compensate...maybe even zero rates or a 1" block? What do you think. I sent an email already to customer service at diy4x before you posted asking them about this. Is this the shackle they made to use for the springs? http://diy4x.com/cart/index.php?rout...product_id=113
03-13-2010, 11:19 PM | #8 | |
Strongman Garage
03-13-2010, 11:36 PM | #9 |
I'll see what he says in his response to the email and post it up
So are you running stock springs in the rear?
03-14-2010, 12:31 AM | #10 |
just found these from sky-manufacturing too...looks like they make them for 67's too
http://www.sky-manufacturing.com/new...duct.php?id=98
03-14-2010, 03:20 PM | #11 | |
Strongman Garage
Even though listed as 69-72 any of the shackle flips work as well for a 67 or 68 just the shackle needs to be different for the 3" bushing on the stock spring.
03-14-2010, 05:51 PM | #12 |
are there any other spring options for the rear. i wouldn't mind converting to a differant spring for better options, i just want the axle centered in the wheel well after i get it in the air. I just don't like the way the trucks look on stock springs. I want the springs to have some arch you know!
Please someone give me a crash course on spring measurements...when they say it's a 52" spring...that's from center whole to center hole right? Ok...maybe i should be asking something differant. what are the stock front and rear spring measurements for the 67 truck. is there a page with this information. how much lift will a 52" spring add to the front of a 67 with out the hanger (cause the hanger adds 4" so how much on top of that will the spring add?) with the rear end, instead of going with just the flip kit and stock springs and doing shackle and add a leafs, is there an aftermarket spring i can use to avoid special shackles to accomodate for the 3" wide spring packs that are stock on this truck?
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 03-14-2010 at 06:07 PM. |
03-14-2010, 06:43 PM | #13 | |
Strongman Garage
the hanger AND springs adds 4-5" of lift the 52" spring has more arch than stock spring. You could use a aftermarket lift spring for the REAR of a 73-87 to further lift it. When saying a spring is 48, 52" or whatever that means from bushing bolt to bushing bolt. I think the stock 68 rear springs are 56" long and are also centered meaning they are 28" from the u bolt to the front and 28" to the u bolt to the back. Some are offset. The custom shackle is not a big deal. I told Kurt at DIY4X the measurements and he made me a set. If I knew about this ahead of time it probably would be the same amount of $$$ as the supplied shackles if not a few bucks more.
03-14-2010, 08:12 PM | #14 |
well if i went with a lifted 73-87 spring i wouldn't need the special shackles right or are they 3" wide packs as well?
and to verify...the spring widths stock 67's front and rear are 3" wide and 73-87's are 2.5" front and rear? i saw a picture of your front b52 hangers have differant mounting locations for the springs...is that for centering the axle in the fenders?
03-14-2010, 09:14 PM | #15 | |
Strongman Garage
Yes the holes are for centering the axle. Also adjustable if using a 52" or 56" spring.
03-14-2010, 09:28 PM | #16 | |
I just sent an email to a spring manufacturer about lift springs so we'll see what they say. btw...i'm talking with Kert at DIY4X about all this still...i'll post up what he says after the email traffic ends
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 03-14-2010 at 09:29 PM. |
03-15-2010, 09:25 PM | #17 |
Well just got done emailing Kert back at DIY4X.com that guys is the sh*t...very helpful and fast responses...couldn't ask for better customer service. Told him what i was after and since it's a special order and i can't call in cause i'm deployed, he's setting it up via paypal for my order (since it is a custom order). It will all be in my garage waiting for me when i get home in May.
Here's what I ordered: - 1 each First Gen B-52 (FGB52) w/6" shackles & greaseable bolts - 1 each First Gen Shackle Flip-N-Switch (00590kb) w/6" Cross-Tied Shackles & Greaseable bolts - 4 each 1/4" thick washers (for the rear spring front hanger to offset the 2.5" wide spring in the 3" wide hanger) I am still waiting on a response from the spring guy Hope he gets back to me soon so i can get these ordered and delivered. (i'm looking for 2" lift 52's and 2" lift 56" centered springs) All this should get me about 6.75" lift, but incase it's not perfectly levelled, i'll be ordering a set of 1" zero rates. I'll have them sitting in the shop if i need them and keep them for use if the front or rear settles. All I need now is a new drop pitman arm, extended brake lines, shocks, and i'll take my driveshafts to a place down the road to get new ones made up after i get it in the air and measure the distances. If i'm forgetting anything, feel free to chime in. I'm going to be upgrading my steering and brakes as well as the gears in the front and rear...still gotta find out what is inside the 10 bolts. I'm looking at rim and tire combos...i am gonna be going with 35x12.50x15 for tires and still not sure what width to go for the rims. someone said 4" backspacing for the rims, but how far out will the tires stick out of the truck? I would like them to come out about a couple of inches or so to give it a nice lifted stance. Suggestions are welcome anywhere ya'll want! Jack
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 03-15-2010 at 09:27 PM. |
03-16-2010, 02:15 PM | #18 | |
Strongman Garage
03-16-2010, 06:37 PM | #19 |
i might just end up with 3/4 ton axles, in board the springs to directly under the frame rails and custom hangers at this rate...i can't seem to get a straight answer from anyone about springs...i wish i was in the states right now...i'd already have this figured out. these damn spring manufacturers are dragging ass right now
all i know about the axles is that they are 10 bolts, i know they are stock...and excuse the new question, but other than Piece of Sh%t...what does POS refer to on this forum...i see it everywhere...i guess it's original parts, but what is the acronym
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 03-16-2010 at 06:38 PM. |
03-18-2010, 01:06 AM | #20 |
was looking around and according to the information on the link below about 1/2 & 3/4 ton pickups i might have found a suitale 52" lift spring for the front.
http://www.stengelbros.com/GMLeafSprings.htm this is a 2" Tuff Country EZ Ride Spring from 69-87 1/2 or 3/4 ton truck that measures 52" and it's centered. http://www.suspensionconnection.com/...on/192702.html Now i'm still looking for a centered 56" 2" lift spring for the rear...i'm so close but still can't find everything...this takes forever.
04-06-2010, 01:09 AM | #21 |
I've been ordering parts and researching for the suspension re-build for when i get home...need some opinions and some help guys!
Ok...well here's a part's list that i've ordered so far: - 1st Gen B52 Hanger Set w/6" Shackles and Greaseable bolts - Shackle Flip Rear with 6" shackles and Greaseable bolts - 2" Softride 52" springs for the front - 3" TG 56 Springs for the rear (these will have to be customized a little) - 1" zero rates - Raised Steering Arm Looking for (if anyone knows where i can get these parts for a good price and pretty much just plug and play, please let me know): - Extended Brake line kit - U-Bolts (front and rear) - (Pretty sure i can use the top plates i have and just get extended ubolts from a local part's store) Waiting to purchase: - Offset Draglink from 4wp - Custom Driveshafts - Shocks (Bilstein) Am I missing or forgetting about anything? Rims/Tires I'm still torn on tires and rims...i know i either want the BFG KM2 or the Goodyear Wrangler MT/R in 35x12.50x15 and i'm leaning more towards the BFGs Rims...i've got it narrowed down between a few candidates... I really like the black look of these uniques...nothing fancy just a glossy black steel wheel. I've ran these wheels before, but not on a classic chevy here's a possible version with a street lock look i like the MT Classic II's as well, but they are polished and since this is going to get driven, i don't want to have to spend countless hours paying attention to the wheels all the time What are your opinions on wheels. The truck is blue as of now, but i plan on going to a 2-tone charcoal grey on black with the beltline and roof being the charcoal grey All inputs are appreciated and welcomed. Thanks, Jack
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe Last edited by Mr-Jack; 04-06-2010 at 06:19 PM. |
04-07-2010, 07:00 PM | #22 |
Strongman Garage
I am probably going to go with M/T classic Locks with gold rings to match my burb eventually. My vote is for the M/T
08-04-2011, 07:40 PM | #23 |
Started tearing my truck apart and got the front end torn out from underneath it...i know it's been a while, but i'll post some pictures up when i get a chance...so far so good though. having to replace some of the old hardware tho...rust isn't something i have patience for, so these old bolts have to go.
