Old 03-13-2010, 08:24 PM   #1
386kustoms
pass side sport mirror ?s
i just bought a pair of mirrors from all our fav auction site and i mounted the drivers one fine, look good and i can see good through it. now the pass is a totally different story. i have it in the right place and when it is turned all the way in i still cant see my bedside on the truck. i almost have to put my head in the center of the cab to see the bedside. is this common with these mirrors? am i going to have to install it basikly just for looks?
386kustoms is offline   Reply With Quote
Old 03-13-2010, 08:31 PM   #2
70Custom10Nut
70Custom10Nut's Avatar
Re: pass side sport mirror ?s
I did the same, and in order to see out of it I have to tilt it all the way in to see. It took me a while to get used to it (my old ones were "big as barn doors") but the look is much better. Cnut
70Custom10Nut is offline   Reply With Quote
Old 03-13-2010, 09:17 PM   #3
386kustoms
yes but even with mine tilted all the way in i still cant really see that good its like it needs to tilt in just a little more
Old 03-13-2010, 11:08 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I had trouble with the one on the Red/White 4x4. Same problem. If I do another set I am going to try and move the pass. side forward a little bit. That should help.
LockDoc
Leon
Old 03-14-2010, 06:06 AM   #5
mikey531
mikey531's Avatar
I just did a search for sport mirror mounting,
http://67-72chevytrucks.com/vboard/s...irror+location
http://67-72chevytrucks.com/vboard/s...d.php?t=179279
mikey531 is offline   Reply With Quote
Old 03-14-2010, 07:04 AM   #6
Jeffs70
Jeffs70's Avatar
Have you tried holding the base and spinning the mirror its self around and then tilting the mirror in and seeing if there is any difference, If I am correct the mirror should be spun around a certain direction to tilt farther.
Jeffs70 is offline   Reply With Quote
Old 03-14-2010, 08:09 AM   #7
DZL1
One day.....
DZL1's Avatar
I have the same issues with mine. What I did was mount the pass side mirror just a little higher and little more forward than it says on the instructions. I did a search on this topic and that's were I found that info to do it on mine. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
Old 03-14-2010, 09:38 AM   #8
386kustoms
if you turn it around it is worse lol i havent mounted it yet but im going outside again to see if i can make it a little better, it may just be poor quality aftermarket
Old 03-14-2010, 03:28 PM   #9
LockDoc
LockDoc's Avatar
[QUOTE=mikey531;3859357]I just did a search for sport mirror mounting,
Those are what I used to mount the ones on the Red/White 4x4 and it didn't work on the pass side.
LockDoc
Leon
