Old 03-13-2010, 09:03 PM   #1
wdsteeves
Question One piece door window kit 64-66 Chev truck?
Is there a supplier for these?I have done a search and see lots of posts re:67-72 but nothing for 64-66.I have seen some in mags but can't find them now.Any help/info appreciated.Thanks
wdsteeves is offline   Reply With Quote
Old 03-13-2010, 09:13 PM   #2
Slow Build
Slow Build's Avatar
Re: One piece door window kit 64-66 Chev truck?
I've only seen one but I can't remember where I saw it. It's hard because both edges of the widow slope in. This company used a deep window help stablize it. I'll try to find it but no promises.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-13-2010, 11:06 PM   #3
wdsteeves
Well I found the CCT mag I was thinking of with the 66 with one piece glass.It desciribes the truck build in detail....except for the door glass.Rats....On with the search
Old 03-14-2010, 12:08 AM   #4
GMCMG
GMCMG's Avatar
Check these out; pricey, but it's what you're looking for:
http://www.nolimit.net/prodinfo.asp?number=GLS%2D6466
GMCMG
1964 GMC 1/2 ton LWB project
- 1982 GMC 6.2 diesel engine/suspension donor
- 1966 Chevy 3/4 ton frame/doors/fenders donor
- tons of parts - cause you can't build a truck without 4 of everything!
2001 3/4HD Duramax Diesel extended cab lwb4x4
1984 Chevy C30 6.2 diesel lift truck (project)
1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!)
glascock.m@hotmail.com
GMCMG is offline   Reply With Quote
Old 03-14-2010, 12:16 AM   #5
Slow Build
Slow Build's Avatar
You beat me by 7 minutes. That's what I found too.
But I'm not sure these are the windows that I originally talked about.
Past GM Trucks:
Old 03-14-2010, 12:18 AM   #6
GMCMG
GMCMG's Avatar
(It was my turn)
But I may have jumped the gun; here is a previous thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=278158
You may want to look further...
GMCMG
Old 03-14-2010, 12:20 AM   #7
wdsteeves
Thanks for the info.I'll call them as I have some questions.
Old 03-14-2010, 12:33 AM   #8
shrunken66stroker
shrunken66stroker's Avatar
The shape of the window in the picture looks wrong. It's probably a stock pic, not specific to 64-66. Let us know what you find out from no limit
shrunken66stroker is offline   Reply With Quote
Old 03-14-2010, 12:35 AM   #9
Slow Build
Slow Build's Avatar
I'm pretty sure those are just generic window pictures. It looks like they used the same pics for all the windows.
Past GM Trucks:
Old 03-14-2010, 01:49 AM   #10
Captainfab
60-66 Nut
The reviews/feedback that I've read indicates that the Nolimit one piece conversion lacks in fit and quality. I believe there is a place that sells just the one piece sized glass if you want to fabricate your own. I'll see if I can find info on who/where to get the glass.
Edit: OK this is the thread I was thinking of.....
http://67-72chevytrucks.com/vboard/s...1&postcount=89
and doing a quick search this appears to bewhere he got his glass....
http://www.vintageglass.com/index.php
Old 06-05-2013, 01:34 PM   #11
1966chevy
1966chevy's Avatar
Here is the one piece glass completed in my 66 truck.
http://www.nolimitparts.com/prodinfo...umber=GLS-6466
Worked well, but if you want to attempt this you really need the tools and patients. Lots of installing, removed, and sizing, etc.
I reinforced the door with extra metal, after I removed the metal under the wing window so the full glass would fit. I also added alignment piece from a ford truck so the window would align in the felt correctly. Custom felt was cut to fit inside and out after windows were installed. See the pictures.
1966chevy is offline   Reply With Quote
Old 06-05-2013, 02:28 PM   #12
wayno
Window's look great though - let's see some more of this truck... looks like a clean machine.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 06-05-2013, 03:12 PM   #13
1966chevy
1966chevy's Avatar
A/C is charged and now working great! Thanks to Old Air Products.
more pictures of my truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=467956
Old 06-05-2013, 03:14 PM   #14
1966chevy
1966chevy's Avatar
Here is another site.
http://67-72chevytrucks.com/vboard/s...=552896&page=2
Old 06-05-2013, 04:29 PM   #15
1963c-10
1963c-10's Avatar
Latest issue of classic trucks has a members truck 64-66 with one piece windows. I can get the members name when home and pass it on.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-05-2013, 06:23 PM   #16
Raked 64
Raked 64's Avatar
I bought a kit and decided not to install it in my truck. It looked a little too involved for my skill set. I will give you a deal if you want the kit. It has the glass, felts, brackets etc.
Let me know.
Raked 64 is offline   Reply With Quote
Old 06-05-2013, 08:39 PM   #17
lil_sahara450r
I had a brief discussion with a guy that had an incredibly nice 66 at a car show. The truck was a full on custom from top to bottom. His exact words regarding the one piece windows was don't do it, that was by FAR the most difficult thing they did to the truck.
'66 SWB BBW Custom cab factory A/C
OEM roller 350/TH400
C-notched and bagged
Frame off in progress!
'69 Camaro Original 327 4 speed - completed
lil_sahara450r is offline   Reply With Quote
Old 06-06-2013, 08:45 AM   #18
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Look to New relic, actually I think it is Nu-Relic, they make power window kits for all vehicles, maybe they have what your looking for.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-06-2013, 09:19 AM   #19
kieth
kieth's Avatar
Not to start a argument but man I would not give up my wing vents for anything, I do like the way the solid window looks but the wing vents really to provide a lot of air when driving and I like resting my arm on the sill and cruising down the road.......good luck on finding the kit. Kieth
kieth is offline   Reply With Quote
Old 06-06-2013, 11:52 AM   #20
lil_sahara450r
^^^ I agree, I like the look of the vent window honestly, and it serves a good purpose on these old trucks...
Old 06-06-2013, 07:32 PM   #21
McCoyAZ
McCoyAZ's Avatar
I talked to a body shop and was quoted $1000.00 per door to do one piece glass and power option on them.
$2000 can do a lot more on a truck build, but I have to say that I LOVE the look.
McCoyAZ is offline   Reply With Quote
Old 06-07-2013, 12:16 AM   #22
jamesrussell26
http://www.vintageglass.com/index.php check this one out not bad prices either
jamesrussell26 is offline   Reply With Quote
Old 06-10-2013, 10:21 AM   #23
McCoyAZ
McCoyAZ's Avatar
http://server1.chevytalk.com/~tony/f...hp?tid/276373/
maybe these guys?
Old 06-10-2013, 07:21 PM   #24
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I always liked the clean look it brings, but I think I would miss the wind they can pull in too. I had a couple of old VW bugs I wanted to do that too, but never got around to it.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-29-2016, 01:59 PM   #25
1966chevy
1966chevy's Avatar
Let me know.
You still have the kit for sale?
