03-13-2010, 09:57 PM | #1 |
Master kill swith location (pic)
Messing around with how/where I would like to relocate the battery, and discovered there was room for the kill switch on the battery box below the cable entry holes.
I've never seen this anywhere. seems like convenient locate unless someone knows a good reason not to put it there. Thanks for your input. |
03-13-2010, 10:30 PM | #2 |
Registered Truck Offender
Re: Master kill swith location (pic)
If tech matters,, NHRA says it must be located on the rear most portion of the car, easily accessible to track officials. Does that fit into your plan?
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
03-13-2010, 11:01 PM | #3 |
Was thinking right rear of bed, the switch would be easy to see, but 90* to the rear exposure.
03-14-2010, 10:52 AM | #4 |
Really all it says is must be located on the rearmost portion of the vehicle and easily accessible from the outside. I don't think you would have any problem with that as long as there isn't a tailgate hiding it.
03-14-2010, 02:54 PM | #5 |
i would also make sure you still run a vent tube with this set up, or the it may cause corrosion on the master shut off switch.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
03-14-2010, 07:39 PM | #6 |
At the body shop.
Here is how i did mine. The tech people pass it. Got it from summit
" That didnt make it any newer " " Dont antique the equipment " |
03-14-2010, 08:41 PM | #7 |
I use the rod type also through the roll pan.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-14-2010, 09:58 PM | #8 |
Here's a picture of mine under the bed with a drop out box... Need to make some kind of shield for it, but it's been fine for about 2years now...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
03-16-2010, 12:08 AM | #9 |
Mean Green
Lets see some more peoples pics of how they did this please. looking very good.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
04-16-2010, 07:29 PM | #10 |
Not sure if legal or not with no rod?
'72 SWB 534" 10.5:1 W/GMPP 290CC Ovals, Wilson Pro flow 2 stage,Transking man. rev T400 W/Trans brake,Moser Dana 60 w/4.30,,Indigo blue W/ghost flames,shaved,smoothed and low,9.40's @ 138 |
04-29-2010, 07:54 PM | #11 |
Here's mine
04-29-2010, 10:18 PM | #12 |
would like to replace my right back up lamp with a switch but will have to trim inter panels for cables 64 C-10
