Old 03-14-2010, 03:39 AM   #1
Farmstore34
Farmstore34's Avatar
Unhappy Clutch spring
Ok I have my clutch return spring hooked to the end of the clutch fork, but where does the other end go? Just the nearest hole in the frame? It don't look right to me.
Thanks!
Farmstore34 is offline   Reply With Quote
Old 03-14-2010, 04:05 AM   #2
Paul M
Junior Member
Paul M's Avatar
Re: Clutch spring
should have one from throw out fork to the clutch pedal arm. so it holds the adjustable shaft to the throw out fork. ill look in the assembly manual rq too.
67-72 Truckless for the moment
Member# 1126
The one that got away http://customclassictrucks.com/featu...001/index.html
Paul M is offline   Reply With Quote
Old 03-14-2010, 04:12 AM   #3
Paul M
Junior Member
Paul M's Avatar
Re: Clutch spring
looks like it shows it going to the frame. should be a hole there close by.
Member# 1126
