![]() Join Date: Jun 2005
Question-Rear Sliding Glass
What NOS rear glass weatherstrip was used with the factory sliding glass?
It appears that the one needed for the slider is the one w/o the trim molding? Somebody out there knows!! Thanks, Dan |
Re: Question-Rear Sliding Glass
depends weasther the truck in question came with or without the trim// you could get it either way
I understand you could get with trim and w/o. The question is what rear glass weatherstrip was used to install a rear slider? Thanks, Dan
Are you asking about the actual window seal or the fuzzie that the sliding windows slide in?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
window seal
if you have trim you use seal for trim if no trim you use seal for no trim
Not sure you can get an oem gasket for these anymore. I will do some more checking with our suppliers. So a NOS might have to be the way to go. We sell a replacement gasket(black Only) for the aftermarket sliders for $50.00. But its for replacing a oem plain window with the aftermarket slider. Not sure its the same as the factory slider
![]() Join Date: Apr 2005
My sliding glass has the stainless trim....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-14-2010 at 11:05 AM. |
I'm not sure Mike. It was in the truck when I got it. Is there a way to tell?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I don't know the differance between the factory and the aftermarket. I grew up with these trucks new and no one I knew had a slider cause all my friends and relatives had basic trucks. could not afford fancy stuff. Most I did see was in camper trucks and did'nt really look at them much. I am sure GM did not make them. One of their suppliers did I would guess. They may be the same as aftermarket one now.
#12 | |
#13 | |
SWB 4x4 Collector
![]() Join Date: Jun 2001
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#14 |
My original sliding back window has just the black seal,no stainless trim.I either got it from LMC or GMCpauls.Can't remember which.
#15 |
Dan,
Here is what the Chevy book shows w/o stainless for a slider. 3940758 71-72 Ser 10 thru 30 (cab) w/sliding rear window 71-72 ser 10 thru 30(cab) (exc. C.C., C.S.) 3940756 71-72 Ser 10 thru 30 (Cab) W/C.C. C.S. (exc. sliding rear window) If you need the WS wo stainless, I have an NOS I would sell for price of Repro. John Last edited by John H.; 03-14-2010 at 02:56 PM. Reason: added part numbers |
#16 |
Here was my 72 Sierra Grande 72 with factory slider and 19K original miles. |
#17 |
![]() Join Date: Jan 2002
My 72 super has a factory rear slider - SPID option number 1 A2810 Rear Window Sliding. The frame is aluminum with stainless steel trim normal to all supers. Doug
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
#18 |
SWB 4x4 Collector
See that is what I meant by my first statement. The factory sliding windows are stainless framed windows. The black framed windows are aftermarket windows. I do agree however that your upper trim package trucks would get the stainless trim weatherstrip, and the base models would get black rubber. Trevor
#19 |
Right you are Trevor! Doug
#20 |
Guys, I appreciate all the info!!! It appears that the slider could have come both ways, with the parts book painting a different picture! I was always confused why? Chevrolet and GMC, actually GM as they did it in the cars as well, would each use different suppliers for the same part. I would guess the slider that will accept the ss trim allows clearance and the other dosen't. Thanks for everyones feedback and John H for the wonderful pics of your gorgeous 72 BB SG. I'll PM you on the seal. Thanks All, Dan
